Drying time for outdoor fire
Discussion in 'The Wood Pile' started by Eddie Hughes, Oct 4, 2020.
  1. Eddie Hughes
    Eddie Hughes
    Swansea, Wales, U.K.
    I can’t find the answer to this question anywhere online.
    I’ve had freshly cut wood for just over a month now, under cover so it hasn’t been rained on, I have an outdoor chiminea so I know I don’t have to worry about seasoning it properly. The wood I have under cover is sounding pretty good when I bang it together. I’m itching for a fire but I don’t want to waste my wood by burning it too soon .
    I’m wondering if anyone else has been in this predicament, trying to figure out when freshly cut green wood is ready to burn on an outdoor fire .
  2. sirbuildalot
    sirbuildalot
    Mass
    What type of wood is it? Most woods will burn pretty poorly after only one month of seasoning. Lots of smoke and little heat. You’d be better off going to a construction site and getting some scraps of kiln dried lumber.
  3. Eddie Hughes
    Eddie Hughes
    The stuff I got under cover is a type of conifer and pine. I have burnt Timber from a construction site before but it’s just not the same as a proper log I find. If it’s not ready I’ll just wait it out.
  4. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Get a moisture meter and check it out. You can get a decent one for under $30. Check out Lowe's, Home Depot & Amazon.
  5. sirbuildalot
    sirbuildalot
    Mass
    If its softwood you could get away with burning it. Pine seasons fully in about six months. I’d say go for it. It’s not like you’re trying to contain the heat. May be a little more smoke then if you waited a few months, but it’ll burn.
  6. Eddie Hughes
    Eddie Hughes
    Thank you, great help. Tonight would’ve been a great night for it, no wind, moon is out, but too late now, so it’ll have another week of drying now at least
  7. sirbuildalot
    sirbuildalot
    Mass
    I’d make sure it’s split fairly small. That should help offset some of the limited seasoning
  8. thewoodlands
    thewoodlands
    We have an outdoor fireplace we burn in, I always make sure we have kindling to start the fire and then increase the size that goes on until it's good and hot, after that everything split burns hot and fast.
    We always have split dead pine undercover to mix in with some unseasoned pine.
  9. Timberdog
    Timberdog
    Az
    If you are burning outside it’s kind of a moot point as you have no stove pipe or chimney to worry about building up creosote in that might eventually catch fire and cause your whole house to burn down. So if you’re burning in an outdoor fire pit or chiminea just whenever the wood will burn and hold a flame.
  10. Horkn
    This is about it in a nutshell. Wood that isn't fully dry, will smoke more and make less heat, but that's about it.
  11. Backwoods Savage
    You can burn moat any wood right after it is cut. As stated above, the wetter the wood, the more soke there is. If you burn it, then get the fire going a good time before you plan to enjoy it. The more hot coals, the better.
