Trees ID
Discussion in 'The Wood Pile' started by T.Jeff Veal, Sep 17, 2020.
  1. T.Jeff Veal
    I have seen a few trees here in VA that I can't figure out.
    Second tree
    They are in the National Park at Appomattox
  2. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    The first one looks like white ash, which is the first live one I've seen in years. The second looks to shag bark hickory. I can't see the leaves well enough to be sure.
    That's my story and I'm stickin' ta hit! Well, fer now anyhow!
  3. T.Jeff Veal
    I thought the swc8 might be shagbark, I've only seen a few, but the leaves were pretty big. One of the guides wasn't sure either.
  4. Chvymn99
  5. Chud
    Chud
    I’d have to see a closer look at the leaves on the second. The picture looks like a blackgum, but that’s not a blackgum trunk or root flare.
  6. sirbuildalot
    sirbuildalot
    Mass
    I agree the first pic is of Ash. The bark and leaves look correct. The other tree is not a Shagbark in my opinion. The leaves look too rounded, they don't appear to have leaflets of 5, and the bark isn't quite right.
    Soley based on online images, Redbud matches pretty closely.
  7. Eckie
    Eckie
    Like others have said, ash on the first. Not sure what the 2nd is, but I dont think its shag, and dont think it's redbud. I've never seen a redbud get over volleyball-ish size at the base (and that's a biggun), and never a "grown tree" form, always a understory type, and leaves arent right. Sally is here doing her thing, but if I get a chance I'll get pics of redbud for comparison.
  8. Ralphie Boy
    Ralphie Boy
    The second tree looks more like shag higher up. Its an old tree which may make a difference.
    I did some more looking around and think tree 2 is in the hickory family more like red hickory or maybe shellbark hickory rather than shag.
  9. buZZsaw BRAD
  10. Ralphie Boy
    Ralphie Boy
    Could it be a larger version of one of these hickorys?
    Red Hickory
    Shellbark Hickory
    Shellbark leaves
    Makes me wanna say a large shellbark because of the smaller leaves.
  11. Chad88
    Chad88
    Mount Pleasant Mills, PA
    The huge base and semi shaggy bark for the second tree reminds me of an older American elm. I don’t see the teeth and asymmetric base on the leaves though.
  12. Horkn
    Need pics of the leaves to be sure.
  13. T.Jeff Veal
    They were way up high.
  14. Horkn
    Zoom :whistle::yes:
  15. Eckie
    Eckie
    Doesn't look like compound leaves...
  16. T.Jeff Veal
    I did...:binoculars:
  17. maybe tree number 2 is either pignut or mockernut hickory other than that i got no clue
  18. sirbuildalot
    sirbuildalot
    Mass
    I looked at a list of trees in the Appomattox Courhouse Park. There are a ton BTW. I then analyzed the ones I thought could be what you showed us with the second tree. My best guess based on the bark and leaves is Red Mulberry.
  19. T.Jeff Veal
    It has big leaves. Just might be mulberry, didn't see any hickory nuts around.
  20. buZZsaw BRAD
    I dont ever recall seeing you process mulberry Jeff. Any down your way?
    T.Jeff Veal likes this.
