Lovejoy coupler for HUSKEE 35 ton log splitter
Discussion in 'Chainsaws and Power Equipment' started by Johnbright, Sep 13, 2020.
  1. Johnbright
    Johnbright
    Maryland
    Hello to all,
    This is my first time post to forgive me if I do something wrong. I have a HUSKEE 35 ton log splitter (Model #21-53605). It quit running a few days ago and I have determined it is the Lovejoy couplers from the motor to the pump. Just so you know I basically do not know what I am talking about, until a few days ago I did not know a Lovejoy coupler existed. The problem now is figuring out the right coupler. The parts manual only says 1” I.D. Coupler half and 1/2” coupler half. The company says they are out of stock! But when I try to order them, there are just a lot of coupler sizes out there! I would really appreciate your help since I have a lot of wood to split and not much time.
    Thanks!
  2. Warner
    The shaft on the engine is 1 inch and the shaft in the pump is 1/2 inch you can get the parts from northern tool. You will likely need a spider as well.
    Fifelaker, brenndatomu, Horkn and 3 others like this.
  3. Warner
  4. T.Jeff Veal
    Welcome to the club. Lots of great folks here sharing knowledge and humor. Do you have a Bearings and Drive store near you? Or Tractor Supply? Northern Tool? They should be able to help you. Take the old parts with you so they can match them up. We have some great machinists and mechanics...
    Screwloose brenndatomu Chaz SKEETER McCLUSKEY
    There are more, but I can't remember right now.
    brenndatomu, Horkn and farmer steve like this.
  5. Warner
    Sorry my links are not working
    brenndatomu and Horkn like this.
  6. T.Jeff Veal
    Glad you saw this post. I forgot to tag you...
  7. Chud
    Chud
    My local tractor supply has different size lovejoys and the spider.
    If you have one, take the lovejoy to the store to match it up.
  8. Eric VW
    Worked for me bud. :yes:
  9. Horkn
    This. Easy fix.
    T.Jeff Veal and brenndatomu like this.
  10. brenndatomu
    X2...most any farm store will have the common ones in stock...bearing and/or industrial supply houses too.
    Do you just need a new spider, or one of the coupler (both?) halves is torn up?
    Horkn, T.Jeff Veal and farmer steve like this.
  11. mikeward
    mikeward
    Long Island, New York
    Horkn, brenndatomu and T.Jeff Veal like this.
  12. TurboDiesel
    Tractor Supply has them in stock here.
    T.Jeff Veal, Horkn and brenndatomu like this.
  13. TurboDiesel
