Dvl stove stove pipe outlet connection question
Discussion in 'Modern EPA Stoves and Fireplaces' started by fishingpol, Sep 7, 2020.
  1. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I am planning for our stove install hopefully in the next few weeks. All the dvl stove pipe and Class A parts are here.
    We are putting in a Jotul Castine that has the outlet that can be used straight out the back or spun 180 for a top vent set up.
    I have Duravent double wall dvl and plan to use the connector with key damper for the first connection and then up with adjustable dvl to the ceiling support box. The dvl is supposed to set right on the stove outlet collar, no screws. The outer pipe on the dvl sits on the outside of the outlet collar, and the inner pipe with crimps fits inside the stove outlet.
    The issue I have is that the cast iron outlet on the stove is a little short, so the dvl does not seat all the way. The outlet collar is better suited for single wall stovepipe, but we are using dvl up to the ceiling.
    Here is a pic of the first connector sitting on the outlet, not level.
    This pic is the front side of the first connection hitting the outlet. This is where the hang up is.
    First connector moved to level. Blue tape shows how much more it could/should be seated.
    My thought is to cut the outer wall of the first connection on the front side in the contour of where it hits the outlet.
    Any thoughts on this? The inner wall wall will sit down well into the outlet if I go that route. We are farming the install work out for insurance reasons. Ceiling has been opened up and we have a straight shot up between roof rafters. It should install well.
    brenndatomu likes this.
  2. fishingpol
    fishingpol
    Better side view of the outlet collar. Right side near blue tape has angle rise to it, not straight vertical rise.
  3. Eric VW
    Probably don’t want to come up with a decorative set of 4 shims and lift the stove up a touch, eh fishingpol?
    I don’t remember if you’ve already built a hearth or if one was present.
  4. fishingpol
    fishingpol
    Nothing installed yet. The issue is the outlet collar does not have enough vertical wall all around it for the dvl connector to seat. Outlet issue, not stove level issue. I need the connector to sit lower onto the collar.
    brenndatomu and Eric VW like this.
  5. Eric VW
    That’s why I suggested elevating the stove.
    If the collar isn’t level when mounted I would grind it level, and build the hearth a tad higher- that is, if I’m understanding the situation correctly... after all, it is Labor Day and I’ve decided to crack open a yucky soda early.
    :D
    :cheers:
  6. fishingpol
    fishingpol
    The connector slides down into the collar, but won't seat because of the outer wall bottoms where my finger is. It really needs to go in maybe another inch or so.
    Side view.
  7. fishingpol
    fishingpol
    Yeah, no. The stove is level, the collar is level. Eric isn't level...:rofl: :lol::coldone:
    That outlet collar is mounted 45°on the back of the stove. So the connector is sitting on the collar only a half inch or so on the left side in this pic.
  8. Eric VW
    Gotcha.
  9. Eric VW
    Funny guy, eh? :rofl: :lol:
    I’m thinking of that scene in “Goodfellas”....:rofl: :lol:
    So grind that front face of the outlet collar or shape the outer sleeve of the connector....?
    JK.
    Isn’t there a dvl adapter that acts as an interface/extra bit where you drop the male crimp (of the damper/connector) into the adapter female, a ring that the outer sleeve bares on/seals up, with a male crimp below the ring that goes into the stove outlet?
  10. Eric VW
    Something similar to this?
  11. fishingpol
    fishingpol
    Haven't seen one. The install videos on YouTube show the dvl dropping right down on the outlet of many stoves with a normal outlet collar.
  12. Eric VW
    Your stuff ain’t normal like I ain’t level...
    :D
    Sorry bud, kinda teed that one up for me....:rofl: :lol:
    Ima go back to my corner now...:salute:
    fishingpol and brenndatomu like this.
  13. fishingpol
    fishingpol
    I know what you are saying. Single wall crimp down with dvl adaptor.
  14. fishingpol
    fishingpol
    Well, yah certainly shook the crickets off the thread and I thank you for that.
  15. Eric VW
    Here to help.
    :D
    :salute:
  16. brenndatomu
    Can you cut an inch (or whatever is needed) off the outer wall so it will set down on there properly?
    I think they make an adapter pipe that is meant to be used first off out of the stove too.
    And if I recall correctly the space between the inner and outer pipes is supposed to remain unobstructed...
    Eric VW and fishingpol like this.
  17. brenndatomu
  18. fishingpol
    fishingpol
    Eric VW likes this.
  19. brenndatomu
    I know each manufacturer has their own unique way that class A chimney pipe goes together...but I wonder if that Supervent piece would work to start off then switch to your Duravent the rest of the way?
    That outer layer shouldn't be too bad to cut...either use aviation tin snips, or a 4" angle grinder with a cutoff wheel would do a nice job on that...just mark it in pencil, then take your time and carefully follow the line...mist a bit of high temp black spray paint on it if the cut shows (it shouldn't)
    Also, just FYI for anyone not familiar, red handled aviation snips are for cutting on the right side of something (cutting to the left) so some people call them right handed, even though they can be used with either hand...and then you have the green handled snips, which is the opposite (cuts to the right) and yellow which is meant for straight cuts...but any of them can do straight cuts also...
  20. fishingpol
    fishingpol
    I could check the specs on the diameters of both brands. Slip fittings, no twist locks until Class A up top.
    I have snips, the outer pipe is not too thick.:yes:
    Thanks for the advice brenndatomu
    Eric VW and brenndatomu like this.
