Production Woodstock IS
Discussion in 'Modern EPA Stoves and Fireplaces' started by My IS heats my home, Jul 29, 2014.
  1. Highbeam
    Highbeam
    Some, maybe most, folks also fall back on their central heating system to cut off the lowest parts of those temperature swings.
    Chaz, NVhunter and chance04 like this.
  2. NVhunter
    NVhunter
    Northern Nevada
    Yep, this is one reason why I took up "secondary" heat source of a wood stove. I try to use the stove for most of our heating needs (keep our monthly gas bill down) but the furnace is there if need be to pick up where the stove has trailed off, which is usually around 4 or 5 am before I can tend to the stove before I head to work. The stove is "Secondary" because we have a gas furnace which is listed as the primary heating system with the insurance company.
  3. Canadian border VT
    Mike I had no longer with company went to @lorrin
    Chaz and Stephiedoll like this.
  4. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Thanks for that update, I did not know. I think it was Thursday last week I forwarded my last email to Mike on to info address so maybe give it a few days. If I don't hear anything in the next couple days I will give them a call. I know my procrastination will be working against me big time this time of year. Thought about waiting until spring again, but I know I will just put it off again. Hate to loose out on their offer to repair it.
    Chaz, chance04 and Canadian border VT like this.
  5. Rich L
    Rich L
    Eastern Mass.
    Stephiedoll I see that you wrote that you hope that the IS is as good as the Quad was.What did you like about the Quad and why didn't you just get another one.
    Chaz likes this.
  6. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Rich,
    I think a lot of that centers on the fact we purchased the Quad used for $500 and ran it hard as it was a small 2 cubic foot firebox, if I remember correctly. Also it never gave us any issues other than a door gasket and the fiberboard at the top (normal wear items). At the time the Idea Steel was released for field testing I was looking hard at the Quad 5700st. Can't remember what the price was on it, but Quads are not a cheap stove.
    The Woodstock is a beast when cranked up with almost double the firebox. As this is a secondary heat source to our nature gas furnace I'm not positive spending $2,500 on the WS was the brightest move, but do love the stove and do not regret the move. It has cut our wood consumption down at least a third plus we don't have to run the stove as hard for out 2,300sf+ raised ranch. Most winters we can all but turn off the furnace. When I discovered the crack that others were seeing I was heartbroken to say the least. As it was out of warranty I never dreamed that Woodstock would cover it, why should they as it was 4 years old. But, as other's have said, they are going to take care of all expenses, other than the pellet, and in my case, getting it to the terminal as I picked it up there. Lorin emailed me yesterday about Mike being gone and is getting the paperwork together for us to drop it off at ABF.
    If you're looking for a stove I agree with others that Woodstock should be on the short list. As it does have moving parts and the cat. it will have more maintenance and upkeep. I got 3 years out of the cat. but that is to be expected. I got in a gasket kit for the stove along with 2 cats last fall but only installed the cat so far. I also need to order a new radiator as mine is warping and flacking quite a bit. Writing is not my strong suite but hope this helps some.
    Stephanie
    Chaz, Smokey jeff, chance04 and 3 others like this.
  7. Rich L
    Rich L
    Eastern Mass.
    Your response is great.I enjoyed your feedback.I didn't understand what you meant by pellet and the need to order a radiator.Are you telling me the stove has some kind of radiator in it ? It's good to hear that the stove has dealt with your winters.I suspect that your winters are very frigid. I've have dealt with many stove manufactures and no one I dealt with comes close to the service Woodstock provides.Hopefully you'll have your stove back in time for the heating season.I have a feeling that in my area anyway we'll have a cold winter.Thanks .Take care.
    Chaz and chance04 like this.
  8. CoachSchaller
    CoachSchaller
    Southeast Michigan
    The radiator is a steel piece that lives between the cat and the top of the stove. It takes the heat of the cat and keeps the top of the stove from failing. They had some issues with them but have added a stainless steel piece to help out. Some might consider this piece a consumable.
  9. Rich L
    Rich L
    Eastern Mass.
    Thank you Coach.Since I'm old school I didn't realize how many parts go into the making of this stove.
  10. Rush Battle
    Rush Battle
    WNC
    Pellet = pallet. She had to find a pallet to ship it to WS for repair.
  11. Rich L
    Rich L
    Eastern Mass.
    That makes sense,thanks.
  12. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Spelling not my strong suit.
    Thanks and you are correct.
  13. mat60
    mat60
    ME
    Im the king of bad spelling here.:smoke:
    Stephiedoll and Chaz like this.
  14. Canadian border VT
    Drove mine down as only hundred miles and I need it back sooner.. plus NH is a great place to spend some $. A3B2A31F-5F81-4E47-A4A6-CAD068553F5F.jpeg
    Highbeam, mat60, Stephiedoll and 3 others like this.
  15. brenndatomu
    You get a new :tractor:?
    mat60, Chaz and Canadian border VT like this.
  16. BDF
    BDF
    Yeah, I called Woodstock yesterday and asked about an approx. ETA on my stove (they have it now) and Laureen (sp?) said she would get back to me when she knew something about it. No call back yet. But she did say that 1) they have had some employee changes and 2) they are buried with work. I still have confidence in them but am just a little wary now :)
    And yep, you are going to need it back sooner than I do..... for sure!
    mat60, Mitch Newton, Chaz and 2 others like this.
  17. Canadian border VT
    No my buddy neighbor down street.. he has forks I don’t.. We always laugh and joke because his tractor is newer and has a cab
    This is a 75 Horse but smaller than my 50 hp
    mines paid for.. I win
    mat60, chance04, Chaz and 1 other person like this.
  18. Chaz
    Chaz
    Southwestern NY
    :dancer::rootintootin:
    JackHammer, mat60, chance04 and 2 others like this.
  19. Flamestead
    Flamestead
    Windsor County, VT
    Lorin. I have a good friend who is “Lauren”, so I stumble over Lorin’s spelling, too.
    Chaz and mat60 like this.
  20. Stephiedoll
    Stephiedoll
    Omaha, NE.
    We've been talking, and debating on seeing if they will let us wait until spring. 1oof on Sunday but Tuesday the high will be 54f. But that means dragging the beast back in to the house.
    Chaz, mat60 and chance04 like this.
