MS250 Oiling
Discussion in 'Chainsaws and Power Equipment' started by Skier76, Aug 30, 2020.
  1. Skier76
    Skier76
    CT and SoVT
    There are many threads about this issue and I tried a potential solution this week.
    I’ve been cutting a lot lately and the chain and bar were getting hot on my saw. I could see heat marks on the bar and the chain was stretching. The saw is is an MS250 with an 18” Stihl bar and a Stihl yellow chain. Chain was sharp and regularly spitting out good chips.
    I opted to open up the oiler holes on the bar to I believe 3/16th. I used a stepped bit and cleaned things out afterwards.
    Seems to have worked well. I didn’t have the issue I had prior. The saw still doesn’t sling much oil, I think that just due to the design.
    I have more cutting to do and will report back when I get in to cutting a few big logs.
    farmer steve likes this.
  2. farmer steve
    farmer steve
    top of the hill york co. PA.
    I'll make this an oil thread.:rofl: :lol: What oil you running in the warmer summer temps? I know my ms250 was a little stingy. Usually a 1/2 tank of oil to a tank of fuel. I was running a 3/8p 16" on mine.
  3. Fifelaker
    Fifelaker
    Fife Lake Mi.
    The bluing you seen on the bar is from ihe induction hardening process, not from oil or the chain.
    Steel has to get north of 750°F before it will turn blue.
    Nixon and farmer steve like this.
  4. Skier76
    Skier76
    CT and SoVT
    I'm running what they had at the local Wally World in NH; Black Max I think? Before that, it was Poulan oil.
    That's good to know on the bluing! Thank you for that.
  5. farmer steve
    farmer steve
    The reason I asked was because some oil weights don't do as good in the summer. To thin.
    Skier76 likes this.
