This is going to be a problem...
Discussion in 'The Wood Pile' started by JackHammer, Aug 26, 2020.
How should jackhammer bring down this tree?
  1. Call a professional
    11.1%
  2. Chainsaw
    33.3%
  3. Fell it by hand
    22.2%
  4. Give it time and the tree will fall on its own
    33.3%
  5. Car jacks and levers
    0 vote(s)
    0.0%
  6. Dig underneath it
    0 vote(s)
    0.0%
  1. JackHammer
    JackHammer
    Video: https://files.catbox.moe/ybmrlc.mp4
    This tree is in my yard on the back acre.... I am the only person that goes down there. I cut the tree down but the branches became tangled in a neighboring tree. I was thinking it would fall down on its own but a year later, it is still hanging on. The tree has slipped and now the bottom is on the ground though.
    Any ideas to get this tree down? I have tried pulleys, jacks, levers, chain and rope.... It seems dangerous to go after with a saw. The tree is pretty volatile and moves quite a bit. I can get my lawn tractor back there but the area is wooded and a truck for pulling is out of the question.
    JoeinO, Horkn, Boogeyman and 7 others like this.
  2. sirbuildalot
    sirbuildalot
    Mass
    No face cut??? No way to control where it goes that way.
    Personally I would pull it from the bottom with a chain. If you dont have a vehicle that will pull it, id use a come along on a nearby tree and pull it that way.
    JoeinO, Hinerman, Horkn and 12 others like this.
  3. buZZsaw BRAD
    Any pics of the top to see how its hung up?
  4. JackHammer
    JackHammer
    It really doesn't look like much. Just a huge cluster of branches. Needless to say, I expected them to separate when the tree was cut.
  5. JackHammer
    JackHammer
    That's a really good idea. I have never seen those. I did use 4 car winches but they weren't large enough. I will give it a shot with a come along and a chain. Stay tuned...
  6. savemoney
    Be very very careful with that poison Ivy. Looks like it is real thick there.
  7. The Wood Wolverine
    +1 ^^^
  8. JackHammer
    JackHammer
    I am very good friends with ol' ivy. Actually, that is the thing killing most if my trees. That, and grape vines.
  9. Bill2
    Bill2
    New hampshire
    x2
    Horkn, Screwloose, Chaz and 2 others like this.
  10. +3
  11. Ron T
    Ron T
    Northeast Ohio....Bowdil
    This....can you get close enough with tractor or 4x4?
  12. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Chain/rope and a tractor or truck.
    Or hang on and me an da boys will change course an be right over wit da heavy stuff! :rofl: :lol:We get dat sucker down!
  13. Chud
    Chud
    Avoid walking under it and see how long it takes for gravity to work.
  14. JackHammer
    JackHammer
    I don't have access to a 4x4 and it is pretty far off of the path. I can get my lawn tractor maybe 30-40 feet away but that feels pretty far. I can set up the tire chains so maybe that could be a solution after all. I thought of this earlier but at the time, my 42" mower wouldn't stand a chance. Now I have a 54", 2 cyl. that might have a shot. I still think that the walk along winch solution might work too.
    Ps - you guys are putting me under some heavy pressure here... I better get this thing down!
  15. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Maybe some tannerite? Then you could show cigarsmokingzombie how it’s done :rofl: :lol:
    Horkn, Stephiedoll, billb3 and 11 others like this.
  16. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    I have had that before, I just keep cutting rounds off from it tell it goes down... Not the safe or recommend way but works.
  17. MAF143
    MAF143
    North Central OH
    Grapevine, Poisin Ivy, Honeysuckle, and a couple other vines were thick in our woods five years ago. I've been working hard and getting that stuff under control and getting the forest healthy again. I've also been culling out stuff that will never make nice logs and allowing the nice timber to get more light and nutrients.
    I get a tree hung up every once in a while because some of the areas of our woods is way too thick and sometimes there is no clear fall path to drop them. I'm lucky here though as I can get the Fergy in most areas of the woods. Fergy and chains have been able to get my hang ups down.
    However you end up getting it down, be safe. Think it through and get a good plan in place, you know the situation and your abilities best. No pressure, no judgements here. I have a rope come along also and it comes in very handy at times.
    Midwinter, Steve, Horkn and 6 others like this.
  18. Screwloose
    This is what I do also. . I bore through on a 30°ish angle at the height your comfortable with leaving a bit uncut on top and cut straight down leaving a couple of inches of wood. Then an inch or two below the bore cut cut up from the bottom until it cracks and falls. The wood left on top will peel slowing the action a bit.
  19. jo191145
    Well she’s hanging in the air already. Only one thing left to do at that point. Pull. Helps a lot to determine the correct direction to pull unless you have a bulldozer :) Analyze the snag a bit before deciding on which direction is easiest to rip it free. Quite often the best direction is straight back towards the stump. Good luck.
    Vines in the tops are a real drag.
  20. Screwloose
    I HATE vines !! I'm cutting in Tarzan town now and it's a chit show.
