Jeez.....can't pass it up.
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Aug 16, 2020.
  1. brenndatomu
    I have a couple of $20 saws...Craftsman/Poulan Pro though, not a Stihl...neither one needed anything other than a knowledgeable operator though...my cheapest Stihl was my MS290 at under $100, after replacing the coil. :saw:
  2. Screwloose
    20200823_203141.jpg 20200823_200124.jpg 20200823_200134.jpg 20200823_202946.jpg
    Everything is clean except the oil pump and coil.
    I want to put in the clutch driven adjustable oil pump as the case is machined for it. Anyone have any idea on the cost of a stihl kit #1121-007-1043 ? Or maybe aftermarket?
    Thanks all !!
  3. brenndatomu
  4. brenndatomu
  5. buZZsaw BRAD
    Great score. Even for parts $20 is a steal. Great saw for porting from what ive read on here.
  6. Screwloose
    No way I'd run it all caked up like it was.
  7. Screwloose
    I bumped into that earlier but it seems that the stihl number 1121-007-1043 is a "kit". It includes the pump, worm gear, bushing, washer and clutch drum. Other places are using the number for just the pump. It needs all of the parts above for the conversion. On ebay a place called "chainsaw conservation components" lists the kit but says out of stock, why it's still listed is beyond me. Not against aftermarket but I see them starting at $12 bucks. I don't want to buy crap. Haven't bothered my dealer yet as I then feel like crap if I go somewhere else. Maybe the grand huskihl will help set me straight.
  8. Screwloose
    It's definitely being considered for a appointment withhuskihl but then the 661 is in the running......or maybe both.
  9. Eric VW
    Hard to keep the $ hidden, eh Keith?
    :makeitrain":makeitrain"
    :salute:
  10. brenndatomu
    huskihl would have cleaned it up for ya before reassembly...he's good like that...;) :saw: :thumbs:
  11. huskihl
    huskihl
    The non-adjustable one actually oils a little bit better than the adjustable. It still pumps a little bit of oil at an idle so when you start cutting there’s lots of oil on the chain. Most prefer to leave it in if it works fine
  12. huskihl
    huskihl
    $20 is $20...
  13. Screwloose
    Well I already have the mask....mize well hit a bank.
  14. Screwloose
    Great, I'll leave it continuous then. Although the existing pump is plastic and I believe it is leaking so I'd like to replace it anyway. I'll just get the standard pump from my dealer. Thanks Kevin, you saved me some money.
  15. Eric VW
    Right- you’ll get to pay him the money he saved you saved... later. :D
    :salute:
  16. Screwloose
    Well to be fair.....a while back I showed her a picture of the XS sticker and I said wanted one on my saw.
    With a puzzled look she says "then get a sticker".
    So I think that's a full endorsement.
  17. huskihl
    huskihl
  18. Screwloose
  19. Screwloose
  20. brenndatomu
    Chazsbetterhalf and T.Jeff Veal like this.
