Spitting out metal
Discussion in 'The Wood Pile' started by jrider, Aug 21, 2020.
  1. jrider
    jrider
    Had my 32” bar on cutting some big oak. Was almost through a cut and bam, felt like I hit metal. Pulled the bar out of the log so see a piece of metal jammed between the chain and bar. Took the bar off and this is what spit out. I am writing this as I sit in my saw shops parking lot. Ugh!
  2. Backwoods Savage
    Ugh is right!
    Midwinter, brenndatomu, Chaz and 4 others like this.
  3. mike bayerl
    mike bayerl
    Phew. Look like you just busted the sprocket and at worst did some damage to the clutch/bar/chain. Must have sounded scary. At least it doesn't look like damage inside the cylinder. Still must be a pain in the butt.
    Midwinter, Chaz, jrider and 2 others like this.
  4. bde269
    bde269
    eastern south dakota
    yuck that sucks !!! hopefully she will be screaming soon
    Midwinter, Chaz, jrider and 1 other person like this.
  5. Eckie
    Eckie
    Oh my o_O
    Chaz and Midwinter like this.
  6. buZZsaw BRAD
    Broken sprocket! That $@#%$! Never happens at a good time does it? Did they have the part in stock? Easy fix i think?
    Sandhillbilly, Chaz and Midwinter like this.
  7. brenndatomu
    So you hit metal and that broke the sprocket, or the sprocket was the metal?
  8. jrider
    jrider
    I dropped it off and they called about an hour ago saying it was done. Wife is out running errands so she’s picking it up
  9. jrider
    jrider
    Sprocket was the metal
  10. Ronaldo
    Ronaldo
    Have never seen that happen before. Crazy....
  11. jrider
    jrider
    Second time for me
    buZZsaw BRAD and Chaz like this.
  12. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Are these chinese or Oregon sprockets? I have never seen a sprocket let go like that, almost cut in half yes, but not radially like that.
    Chaz likes this.
  13. jrider
    jrider
    Said Oregon right on it
    buZZsaw BRAD likes this.
  14. buZZsaw BRAD
    With all the cutting you do im surprised your saws dont break more frequently.
    jrider and Sandhillbilly like this.
  15. jrider
    jrider
    My saws do some serious work but that’s what they’re made for right?
  16. buZZsaw BRAD
    I know you have that 038 which was a pro model saw. Dont know what the other saw(s) you run.
    What did the dealer say when he saw the broken sprocket? Had he ever seen one break like that before?
  17. jrider
    jrider
    It was just the sprocket thankfully. A quick and easy $15 repair
    Ronaldo, mike bayerl and brenndatomu like this.
  18. jrider
    jrider
    I just run the 038 magnum and this one that broke (echo 8000). I do have a Stihl ms260 that I basically only use if I happen to be limbing. I’m not one of these CAD guys (don’t shoot me fellas). I just like to keep things simple.
    As far as the busted sprocket, it’s the second time on this saw and I must not be alone because he had it in stock.
    buZZsaw BRAD and brenndatomu like this.
  19. metalcuttr
    metalcuttr
    western WA
    Good to hear that!
    jrider and brenndatomu like this.
  20. mike bayerl
    mike bayerl
    So glad to hear it didn't do any more damage than that. PHEW!
