A reminder to stay safe out there: Storm damage tree cleanup
Discussion in 'The Wood Pile' started by Deer Meadow Farm, Aug 10, 2020.
  1. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    As I mentioned in the Isaiah thread I had some trees come down in the storm. This big pine was one of the ones I mentioned. Notice how its down between the two trees standing, but still looks relatively straight. 030.JPG
    I started walking along the right side of the tree marking it off for 12' lengths for the sawmill. Once I got to the second tree it was stuck against I switched sides and continued marking. When I got ready to make my final cuts, I started back at the root ball but I wasn't able to cut all the way through due to the dirt. I moved up to the third 12' mark which was near the second tree. I was cutting from the right side because there was less debris in the way on that side. As I was cutting, I noticed the cut opening up slightly towards me. I realized that the tree was under tension and that I should switch to the other side of the tree to finish my cut "just to be safe". I didn't realize just how much tension it was under. When I was close to finishing the cut, the tree snapped through the rest of the cut and jumped about 4+ feet to the right (look at the difference between the location of the logs at the third cut up.) There was no roll in that photo, just horizontal movement.
    If I had finished the cut from the right side where I had been, I would have easily broken one or both of my legs. Or worse.
  2. CtRider
    CtRider
    Agreed. Look out for widow makers too
    Same scene, different angles
  3. The Wood Wolverine
    Good to read you averted catastrophe. That sure was a LOT of tension too. Your instincts did well.
  4. Backwoods Savage
  5. mirnldi
    mirnldi
    Too much drama for a few splits of ash.
    Midwinter and Chazsbetterhalf like this.
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Very good PSA. Glad you didn't get hurt on that.
  7. Chaz
    Chaz
    Southwestern NY
    Definitely good you kept your eyes on it
    Deer Meadow Farm
    :yes:
    And definitely check the canopy as well.
    :binoculars:
    :hair:
  8. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Huh?
  9. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Very good reminder. I have cut some mangled messes and you have to stay very aware of what is under tention. My dad has a scar on his head from a widow maker that came down and knocked him out. Always have to be aware.
  10. MikeInMa
    Good of you to know what to look for. Thanks for sharing the reminder!
  11. mr.finn
    mr.finn
    Mass
    Glad you took the time to assess the situation and come up with a safe plan to avoid anything happening.
    Chazsbetterhalf likes this.
  12. jo191145
