Weeds between the Stone or brick walkway? What do you do?
Discussion in 'The DIY Room' started by don2222, Aug 9, 2020.
  1. don2222
    don2222
    Salem NH
    Hello
    I just weed wack them and they came back so quickly!!
    This time I did pull some by the root, but the other ones I burned with a torch. Does this help or is there a much better way?
    Does Roundup work?
    Any good tips?
  2. fox9988
    fox9988
    NW Arkansas 72717
  3. Screwloose
    Ortho ground clear or roundup.
  4. TurboDiesel
    This^^^
  5. TurboDiesel
    for broadleaf, add an ounce of 2,4, D
  6. don2222
    don2222
    Salem NH
    What is that?
  7. TurboDiesel
    2,4-D is a herbicide that kills plants by changing the way certain cells grow. 2,4-D comes in several chemical forms, including salts, esters, and an acid form. The toxicity of 2,4-D depends on its form. The form also affects what will happen to 2,4-D in the environment and what impacts it may have, especially on fish. 2,4-D is used in many products to control weeds, and it is often mixed with other herbicides in these products
  8. Screwloose
    There are a few types of roundup. Some only stay active a short time. You want the 365 stuff.
  9. jrider
    jrider
    Burn them. No chemicals
  10. Chvymn99
    I don’t personally use round up. I use the stuff from the agriculture store.... I seem to having a better performance out that stuff... as mentioned earlier, I use a 2,4D along with the grass/weed killer.. It’s a Gorden variety... at 2%....
  11. don2222
    don2222
    Salem NH
    Last night I used the roundup on the burned roots that I found in my garage so between burning and this, I will see what happens. :)
    Thanks everyone! :)
    My friend said use it in the evening so the hot sun would not dry it to quickly. :)
  12. brenndatomu
    This ^ ^ ^.
    Regular Roundup will kill the weeds, but they will be back in 2-3 weeks even bigger and badder!
    I use Groundclear...but anything with a residual effect will keep 'em down 3-6 months. :yes:
  13. bushpilot
    bushpilot
    Eastern Washington
    I weedwhack them down, and then let them be. With a little mindset change, they become a feature rather than an annoyance.
  14. brenndatomu
    Yes...my mindset has been changing gradually over the years...we have a lot more "features" in the landscaping than used to be...the former owner is probably rolling over in her grave, she was a huge garden club nut...had pics of the garden in the local paper more than once.
    The attitude I have now is to just do what we can, and if we can keep things from getting out of control...good enough.
    Horkn, fishingpol, metalcuttr and 5 others like this.
  15. Chazsbetterhalf
    Chazsbetterhalf
    My son uses a mix of vinegar, salt and dish soap. Can get the recipe online.
    metalcuttr, farmer steve and don2222 like this.
  16. don2222
    don2222
    Salem NH
    farmer steve and Chazsbetterhalf like this.
  17. farmer steve
    farmer steve
    top of the hill york co. PA.
    Your best bet is to get a generic roundup with at least 41% active ingredient. Like TurboDiesel said mix a little bit of 2,4,D in with it. Get the amine formula. Just keep away from any desirable plants. The 2,4,D is for broadleaf weeds. A surfactant added to your mix will give better results. If you know any farmers around you ask them were they get there chemicals.
    EDIT. Whatever you get,READ THE LABEL!
  18. Semipro
    Semipro
    SW Virginia
    I believe Roundup is systemic and really only works if applied to growing foliage.
    I'm avoiding chemical weed killers and plan to try a torch soon (in the spirit of the forum and pyros everywhere).
    Any tips on that would be appreciated.
  19. don2222
    don2222
    Salem NH
    My friend uses a torch but it was not enough so he recommended roundup after using the torch.
    So that is what I did. :)
  20. Canadian border VT
    Straight vinegar kills most plant and environmentally friendly, and cheap
