Ever Dreamed Of Having A Custom Saw Built?
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Jun 24, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Do you guys also want to choose the top handle type half or full wrap?
  2. Cut4fun
    Cut4fun
    OHIO Redneck
    I'd put that option there if both on hand Tim.
    Chvymn99 and Oliver1655 like this.
  3. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Well, I don't have either in stock so will have to order no matter which they choose. So, I'll put both choices up.
  4. Cut4fun
    Cut4fun
    OHIO Redneck
    A guy from Sandusky brought a 372 he had with a aftermarket US or USA brand full wrap that was sweet. Dont know if it is cheaper then OEM or not.
  5. mdavlee
    mdavlee
    Pro safety makes one for them.
  6. Cut4fun
    Cut4fun
    OHIO Redneck
    One I am thinking came from Madsen's.
  7. mdavlee
    mdavlee
    They sell pro safety stuff. I don't know if the guy that made handles for stihl ever made some for the 372.
  8. Cut4fun
    Cut4fun
    OHIO Redneck
    Who know my ole memory could be confusing it. Know it was a nice aftermarket full wrap though. Not oem. Felt like thicker grips like I like.
  9. mdavlee
    mdavlee
    That would be pro safety. They are a little bigger and more comfortable to me also.
    Cut4fun likes this.
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mdavlee, I think you are right, a while back I checked out Madsen's and could find the Pro Safety stuff but did not see any thing for the 372.
    mdavlee likes this.
  11. mdavlee
    mdavlee
    I know pro safety made one for it. I know a local to me that has one. He had an accident with the OEM wrap handle.
  12. Cut4fun
    Cut4fun
    OHIO Redneck
    Just looked on their website and Pro has them for 372 395 and other stihls except 441.
    mdavlee likes this.
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Thanks Kevin, some of the firewood suppliers I do saws for have some HUGE guys working for them. Guys with hands like tennis rackets, smaller diameter bars are uncomfortable for these guys, I see saws they use come in with big pieces of hydraulic tubing split and taped around the top handle. These pro-safety bars may be a welcome option.
  14. Cut4fun
    Cut4fun
    OHIO Redneck
    Thats why I liked the half wrap on the 166 and traded my full wrap on the other 166 for another half wrap too. The full wrap was terrible skinny and the half wraps were way thicker on the 166's.
  15. clemsonfor
    Hultz makes 372 half wraps I have a new one at the house.
  16. Oliver1655
    Oliver1655
    Central Missouri
    :popcorn:
    My votes:
    - Piston/cylinder = #5
    - Carb = ? I am a big dummy here.
    - Air filter = Does the large vs standard make any difference in performance when clean? If not, I like the lower profile.
    - Handle = half wrap. I like a compact saw.
    Ps: I think of this thread as broadening my education vs OP making a sale. Teach on.
    Chvymn99 likes this.
  17. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Thank you for your kind words. In answer to your questions;
    The 064 Stihl piston in the 52mm kit makes quite a powerful saw with higher compression than the standard BBK piston or the stock 50mm setup. Did you put your choice in the poll thread, if not, do so please.
    Carburation is a funny thing, if the carb is too large for the case volume then you will not see much difference in performance most likely poorer, they do work well on the BBK with the 064 piston but the only thing that will notice the difference is a stopwatch. Either the 12-B or the RWJ-4 will work on the set of choices I have presented.
    The HD setup does not perform any better than the standard but gives you the 'more manly big saw look'! In limbing situations the HD setup is less nimble than the standard IMO.
    I agree with you on the half wrap unless you are falling or cutting stumps the full wrap gets in the way IMO.
  18. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Oliver1655 likes this.
