2005 Kubota L48. My next work partner!
Discussion in 'Chainsaws and Power Equipment' started by Gasifier, Jul 29, 2020.
  1. Gasifier
    Should be here about 5:30AM tomorrow! :handshake:
    01325FBD-98AF-44A0-9E85-F3EEB43C7258.jpeg 7B173562-E18D-49F5-B909-2F1DD183C997.jpeg 3FDD764C-54B2-444D-9D37-977FA56C939D.jpeg C9CF72F2-DB65-49D2-8579-2FAEFCB154D7.jpeg 241FE48C-5417-43AA-96DF-1EF3B92ECE02.jpeg
    Backhoe comes off and has three point hitch equipment with. :thumbs:
    Hammy, Stinny, Chris F and 18 others like this.
  2. Horkn
  3. Ejp1234
    Ejp1234
    MD
    If I was going to get a Bota, the L series would be it.... much heavier and the backhoe is way more capable.
    Good buy!
  4. Chaz
    Chaz
    Southwestern NY
  5. Chvymn99
  6. Gasifier
    Hammy, Chaz, Chvymn99 and 6 others like this.
  7. Gasifier
    Yes. The TLB series backhoes are strong. I enjoyed reading an owners post on a Tractor site. He said it’s like have a gorilla working with you. LOL
    Hammy, Chaz, T.Jeff Veal and 9 others like this.
  8. eatonpcat
    Congrats on the new machine...
    Hammy, Chaz, Chvymn99 and 5 others like this.
  9. JCMC
    JCMC
    Just outside of Shushan, NY
    :yes: Nice machine!
  10. Eric VW
    Awesome buy! Guess we get to see more terraforming pics, eh Gasifier?
    Hammy, Chaz, Chvymn99 and 4 others like this.
  11. Gasifier
    She got here early this morning.
    2A9643E2-9C51-40CB-B300-3CF91BE6F88F.jpeg F9994481-CBE2-42EE-8F84-94018CBF91CA.jpeg D2C86A75-9145-4550-B448-F72EBE8483FE.jpeg
    Hammy, Stinny, Chris F and 12 others like this.
  12. Gasifier
    And then my luck happened. :confused: All hydraulics worked when it came off the truck. Truck left and I checked oil and hydraulic fluid levels. Good to go. Fluids even looked good. Drove it over to my concrete pad in front of barn and tried to take the backhoe off. Not happening. The pins seem to be set up. I don’t know. Probably hasn’t been off in a long time. While moving the rear tires slightly off the ground and then back down to try to loosen said pins the hydraulics stopped working. :picard:My neighbor was walking by and stopped to help. He has a Kubota too. I have owned an L 3710, an L35, and an M59. Three different set ups. And taken the backhoes all off and on many times. I’ve never seen anything like this. The connections are all good. Never disconnected any of the hoses. The levers are all in the right place. No leaks anywhere. The tractor will go forward and reverse. So hydrostatic is working. The boom will swing left to right. But no other hydraulics on backhoe work. No loader hydraulics work. Very strange. Local Kubota dealer sending mechanic over to try to figure it out. Dealer I bought it from says he will pay them. This is very odd. I haven’t even done anything with it yet! :doh: And I tried the “gate valve” under seat. No difference. Weird.
  13. eatonpcat
    That sucks brother..but at least the dealer is gonna cover the repairs!! Little bit of overkill on the delivery rig!
  14. Gasifier
    Mine was the last drop. He had three other machines on when he left yesterday.
  15. Canadian border VT
    Dear Mr. Gasifier I am sorry to learn that my luck has become contagious and you are afflicted with such. Plant a garden cause you will have Chit.
    Hammy, Chaz, Chvymn99 and 7 others like this.
  16. sirbuildalot
    sirbuildalot
    Mass
    Hopefully it will all work out!
    Looks like a nice machine.
  17. Backwoods Savage
    Congtats Gas. I'm sure they will do the fixing right.
    Hammy, Chaz, Chvymn99 and 3 others like this.
  18. Unicorn1
    Unicorn1
    Amarillo, TX
    Sweet setup, hope the fix is an easy one. I could get so much work done if I had one.
  19. Gasifier
    I found a thread on the subject on Orange Tractor Talks. After reading it I read it out loud to my neighbor and the mechanic. Mechanic went to the front of tractor and found the two pumps that run all the stuff that isn’t working. (Three pumps on the tractor. One runs the HST and the swing on backhoe. Other two run the rest of backhoe functions, steering, and all loader functions.) He took front off, battery out, some side bolts, plates, etc. Got to pump assembly and got that all apart and sure enough the coupler that connects to PTO shaft from front of motor, well its splines were all rounded off and shot. Luckily the pump seems to be functioning fine and the splines on it seem okay. So parts are ordered and being shipped overnight for an extra $50. New coupler, two new bearings. Seller said okay to go ahead. Hopefully it will be up and running tomorrow. If they got the call in early enough for shipping. Then we still have to get the backhoe pins free. Seems odd to say, but kind of lucky it went when it did? Because if it went 20 hours of tractor work later..... I’d be paying for it.
    Hammy, Stinny, eatonpcat and 5 others like this.
  20. sirbuildalot
    sirbuildalot
    Mass
    Doesn't sound like it will be too hard to fix.
    Good luck
    Hammy, Chaz, Chvymn99 and 2 others like this.
