Show me your 5 gal fuel can. Any hack?
Discussion in 'The Wood Pile' started by Marshel54, Jul 2, 2020.
  1. Marshel54
    Marshel54
    My can similar to this one.
    Every time I have to fill the lawn mower my can just about leaves me. Throwing it over the hill.
    I have never seen such a dysfunctional and aggravating product. I am not very tall, have a few years on me and to hold a 5 gallon can at chest height while it slowly glug glugs is hard. After the third time that the little titty thingy slides off the rim of the filler nozzle I am ready to throw the can as far as I can
    Any hacks to eliminate the safety feature and get the gas out of the can faster. At the very least I am going to poke a hole in the can with my knife to let it breath.
    Do they make one that actually functions like it should?
  2. Eckie
    Eckie
    Take the nozzle off and use a funnel-if you need to. "Safety" cans are a pita
  3. farmer steve
    farmer steve
    top of the hill york co. PA.
    Marshel54 . I recall seeing a tank vent upgrade for that type of can. It was like the old style vents. I believe you drilled a 1/8" hole and press fit it on. I look for old style cans at yard sales and auctions. I have at least 10 in various sizes. I'm a gas can hoarder too.:loco: :crazy:
  4. Marshel54
    Marshel54
    One of the hacks that I have seen was to take the core out of a valve stem drill a hole and pull it through the can and out the hole. I believe the hole was a 1/2". I will have to research it again. The hack also came with some spout modification that I wasn't sure of.
  5. MikeInMa
    SD Steve, Screwloose, Ronaldo and 8 others like this.
  6. Nitrodave
    Nitrodave
    Grayling Mi.
  7. Horkn
    You all will be jealous of my gas cans. They are old school. Non epa approved new crap.
  8. stuckinthemuck
    stuckinthemuck
  9. Canadian border VT
  10. MikeInMa
    I drilled the hole and used their supplied flip cap vent
  11. billb3
    Every replacement nozzle/spout I've bought has not fit the cans I own.
    Probably just as well as I don't store much gas any more due to ethanol anyway.
  12. MikeSs
    MikeSs
    new have county, ct.
    I have 2 of these in 5gal and a 2.5. Difference other than size is the 2.5 doesnt have the back handle. I like for the top fills.
    Not sure how they do with side or angle such as a saw. 20200702_210213.jpg 20200702_210224.jpg
  13. Canadian border VT
    how many acres do you have?? 5 gallon of 40:1 mix here can be gone in 72 hours between mowers saws trimmers etc etc
    Screwloose, T.Jeff Veal, Chaz and 6 others like this.
  14. XXL
    XXL
    Ontario, Canada
    I used those add a vent caps and it was better than no vent but never really sealed properly. Here in Canada Scepter gas cans brought back the vent about 2 years ago. Bought a new can and kicked the old one to the curb. I also upgrade the low flow vent spout and replaced it with after market no vent spout.
    [​IMG] [​IMG]
    Got a great 2 pack deal on these at Costco for $20 last year.
    Screwloose, T.Jeff Veal, Chaz and 8 others like this.
  15. Loon
    Loon
    North of the border
    The things are stupid! Just drill a half inch hole in the back of the handle.:cheers:
    Screwloose, T.Jeff Veal, Chaz and 5 others like this.
  16. Eckie
    Eckie
    I have a couple of those types. They actually work for me, and I dont mind them. The ones similar to the op's pic are a pain
  17. Mag Craft
    I broke down and bought one of those battery operated liquid transfer pumps from HF. I have to say it really does work good. I do not use a spout anymore or a funnel.
  18. Warner
    I have drilled a hole near the handle and inserted a valve stem with the needle removed. Use the cap to open and close the vent.
  19. Warner
    I use these cans now as well. I find it makes it much easier to fill the saw if you lay it on its side...
    Screwloose, T.Jeff Veal, Chaz and 4 others like this.
  20. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    This is what I have and it’s great. I also have the same for my diesel..
