muffler modding 661 mtronic advice needed
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Jun 17, 2020.
  1. Screwloose
    so what's the word on opening up mufflers on mtronics ? I was thinking about opening up the hole to the size of the deflector and then recalibrating. Naturally I don't want to poof my saw but it sure seems restricted and hot.
    What have you all been doing?
    MAF143, M2theB, T.Jeff Veal and 2 others like this.
  2. Nixon
    Nixon
    West Sunbury,Pa .
    Next time I’m down in the shop , I’ll pop mine off for some pics . Most likely tomorrow A.M. .
    MAF143, Fifelaker, M2theB and 4 others like this.
  3. mike bayerl
    mike bayerl
    Should be easy-peasy. M-tronic will keep if from "poofing" i.e. burning up from running too lean. Def. enlist experience on how much to open it for optimal results.
    MAF143, M2theB, T.Jeff Veal and 3 others like this.
  4. huskihl
    huskihl
    You can drill the spot welds and remove the baffle, open behind the stock deflector, and add a small deflector on the recoil side. That would help
    jtstromsburg, MAF143, M2theB and 8 others like this.
  5. Screwloose
    And then recalibrate it, correct?
  6. Screwloose
    Thanks, no rush on my end just trying to get a plan.
  7. Screwloose
    I'm spooked by the possibility of pizzing of the computer.
    T.Jeff Veal, Chaz and brenndatomu like this.
  8. mike bayerl
    mike bayerl
    um 1140910, member: 4169"]I'm spooked by the possibility of pizzing of the computer.[/QUOTE]
    No worries there. The computer will re-tune by itself after any muffler mod.
  9. huskihl
    huskihl
    You can. If it’s the newer 661 with the V3 coil and solenoid on it, it will calibrate the saw to your new given parameters. On the older saws, it resets the M Tronic to factory specs and starts to learn again
  10. Nixon
    Nixon
    West Sunbury,Pa .
    Here you are . The paper 03BC735E-BAD0-41CE-9542-EB3FBA95E344.jpeg 406E8B4C-8ADC-4AB0-8393-245CB11E30BC.jpeg B25F66FB-10B3-450C-B43F-D3A897A38D9D.jpeg 177A9F17-605E-4BF3-92C0-843AB01923B9.jpeg 5FA6D840-535D-4CB0-B2F6-A49D074704BA.jpeg 0F7C823A-0076-473F-B8C5-1B99EF019778.jpeg is 3” wide , marked at 1/2, and 1” for scale .
  11. MAF143
    MAF143
    North Central OH
    I'm gonna be doing a MM on my new 362 CM soon and was wondering what you guys reccommend for the ratio of the muffler output area to the input area. I've heard two schools of thought on this, output at 70% of input area and others that say to open the muffler output up to 120% more than the muffler input. The others I've done have been in the 70% ish size and have made nice improvements in cut speed, but I'd like to hear a little of the theory behind the number instead of just the number.
    I'm not racing, but sure do like to get the most out of my firewood saws without getting radical or spending a bunch o' cash... Someday I'll send a saw off to get ported, but cash flow restrictions are the main issue for now. Laying down the cash for a new saw was a big step for me at this point but I've been wanting / needing to step into the pro series.
  12. Screwloose
    Thank you. I just don't know much about the mtronic, a bit confused about how it works without monitoring the exhaust.
    huskihl, Chaz and brenndatomu like this.
  13. Screwloose
    Chaz, Nixon and brenndatomu like this.
  14. lukem
    I did my 362CM. Easy job. I just added a hole next to the factory outlet. She's a ripper.
    Easy MS 362CM Muffler Mod
    Chvymn99, M2theB, Screwloose and 2 others like this.
  15. Nixon
    Nixon
    West Sunbury,Pa .
    Yes , the screen is kept in with those tabs .
    Screwloose and Chaz like this.
  16. Nixon
    Nixon
    West Sunbury,Pa .
    I’ve read 80% probably more than any other percentage . But , I don’t think it’s all that critical .
    My MS 460 is opened up more than the 572BB4AC-ED89-4550-8F48-3953E3F25054.jpeg 1678B171-FA23-4C0E-A355-B1FC7809575F.jpeg 4593A1E9-1045-49CB-841D-BA6131A44350.jpeg 661 , and it’s happy to idle , transition ,and run at W/O throttle .
  17. MAF143
    MAF143
    North Central OH
    I can't remember what the factor is, but I know the spark arrestor screen reduces the effective opening by quite a bit and needs to be accounted for. I'm sure there are many other factors a serious engine tuner would consider as well, but me being a firewood, weekend hack wannabe, I'm sure that opening them up to breathe better is going to make a difference whether it's 50% to 150% ratio. I've always heard the talk, and have felt the increases in my own saws even with my own humble hacking, but just kinda curious what some of the pro's have to say about optimum tuning of just a muffler mod on a factory piston and jug, although I'm sure they don't want to give away all their top secret tuning tips.
    Just like with a car back in my day, dropping a set of headers and glass packs in makes a nice difference for me on my daily driver, but showing up at the race track with that as the only mods could be rather embarrasing!!!
    As for my chainsaw, I'm just looking for the best I can do with a scrench, pliers, dremel, and drill on a slow Thursday evening while one of my buddies holds my beer and watches... LOL
    Speaking of beer, it's gotta be 5:00 somewhere... :cheers: :pete:
    Chvymn99, M2theB, Ron T and 5 others like this.
  18. lukem
    With those tools you can always make the hole bigger later.....harder to make it smaller. Drill a hole, run a few tanks of fuel through it, and maybe drill another later if it doesn't seem like much changed.
    Chvymn99, M2theB, brenndatomu and 4 others like this.
  19. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Hey Lukem. Could you show a pic of that? I have a 362 cm would like to see that. Thanks
  20. lukem
