Lithium battery chainsaw thread
Discussion in 'The Wood Pile' started by hovlandhomestead, Apr 6, 2020.
  1. Chvymn99
    I finally got to get the videos... I really like this little saw... it’s got plenty of guts behind it for the smaller stuff. It’s light and quiet... I thought about getting the bigger one like hovlandhomestead but chose not to do to not liking the balance vs. the balance of this smaller one.
    Here are the videos... allows you a little better feel for what can do...
    Chaz, Chazsbetterhalf, Maina and 6 others like this.
  2. buZZsaw BRAD
    I like it. Sounds just like the pole saw i bought last month. Mebbe i can find a cheap used one. How many cuts did you get with one charge Chvymn99 or did you keep track?
    How many batteries do you have? I have three, but I use them on a fairly regular basis, so they're not as good as new.
    Chaz, Chazsbetterhalf, Maina and 5 others like this.
  3. Chvymn99
    I use the 60 volt flex battery... I’ve got 3 of them... they last amazingly well in my mind.
  4. buZZsaw BRAD
    Is the saw a 20 volt model or 60 volt?
    Chaz, Chazsbetterhalf, Maina and 4 others like this.
  5. Chvymn99
    20 volt... but the 60 volt is a flex battery... it can be in both applications.
    Chaz, Chazsbetterhalf, Maina and 3 others like this.
  6. buZZsaw BRAD
    I just watched a video and it warned about using the 60volt flex in 20volt max tools. Showed an impact driver and recipro saw being used then were ruined as a result.
    PREVIEW
    5:10
    NEVER USE DEWALT FLEXVOLT BATTERIES ON 20V MAX ...
    Dunno who to believe???
  7. Chvymn99
  8. Chazsbetterhalf
    Chazsbetterhalf
    The bar is 12" Correct and you cut to what length?
    Chaz likes this.
  9. Timberdog
    Timberdog
    Az
    :saw:
    Chazsbetterhalf and Chaz like this.
  10. Gavorosalini
    Gavorosalini
    Hutchinson KS
    Is your teal one a top handle 10" 18v?
