Need schooling on fancy saw bars
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Jun 13, 2020.
  1. Screwloose
    So I got the 661 with the 36" stihl bar. My normal go to is a 28". I usually use Oregon power match bars but I'm seeing that people have been putting on these sushi bars. What in a 28 would balance nicely, are they in fact better and if so which one and from where ?
  2. Warner
    Isn’t sushi bar a place you go to eat raw fish?
  3. dahmer
    dahmer
    Ellwood City PA
    I’m going to guess you meant Sugihara and auto correct made it sushi. On my 9010 Makita I’m running a reduced weight TsuMura 36” bar and I like how it handles.
  4. Screwloose
    Auto correct is a pia sometimes. Is it relatively stiff ? I have never seen one in person. Looking to have the saw somewhat balanced when I'm carrying it around is why I'm thinking about the reduced weight.
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    4 outa 5 of my saws are wearing sugihara bars. Not sure if I really need em or not but I think they look really good. I did weigh a 28” Sugi against a 24” factory Husqvarna bar (both large mount) and they were the same. 056E27F1-24EB-4193-BBBE-FBB79C17767E.jpeg
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the stihl lightweight is almost a couple oz lighter than sugi in 24" i know we talking about a larger bar here but i dont have the stihl one here to weigh....i prolly have the sugi
  7. Screwloose
    After a bit of searching i found the a member here by the name "fordf150" peddles bars. I sent him a message but haven't heard back yet. Although it doesn't appear that he's been around here for a while so that might not prove fruitful.
  8. Screwloose
    Do you have a preference? I just want the saw to balance as i walk around a lot.
  9. huskihl
    huskihl
    His shop burned and he’s not back up running yet.
    I’d look into Tsumura. They’re a bit less expensive and lighter weight. RedBull on ope used to sell them but I think he’s moved onto other things. Sugi lightweights are almost as heavy as most regular weight bars. But they have really good rails.
  10. Eric VW
    Up there in Ohio??? The converted skating rink building? Oh man, that’s terrible!!!! :confused:
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    No not really.there is a point where balance ain't gonna happen...fo example my 390 with a 32 needs to be picked up by the brake handle
  12. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    huskihl is right the sugi is a tuff bar....i got a bunch of tree buzzards beatin on em...only 1 tree guy runnin es-light
  13. Nixon
    Nixon
    West Sunbury,Pa .
    If you are looking a Tsumura , also look for Total super bars . They are Tsumuras . A bit less $$ when you find them .
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the tsumura is a really good bar too but since tilton eq. went out of business i dont have a reasonable source for them....forester makes a reduced weight bar too,i havent tried any yet
  15. Chaz
    Chaz
    Southwestern NY
    X2 ^^^
    This is the first I've heard of that.
    He put so much time, energy, and money into that place.
    Last I knew he was just about ready to open the shop too.
    Total $ucksville
    :confused:
  16. Screwloose
    What happened to his shop ? Is everyone okay? Thats terrible news...
  17. Screwloose
    I'm hoping it balances enough that I can walk around without it catching on everything. I have a hard enough time getting around already.
  18. huskihl
    huskihl
    Yep
  19. huskihl
    huskihl
    dahmer knows I believe. He’s been in contact with Nate
  20. dahmer
    dahmer
    Ellwood City PA
    Nate has been getting some run around from the insurance company not returning calls. He said that it will probably be spring of 2021 before he actually has a brick and mortar business up and running again. I do know that he had hundreds of bars destroyed in the fire.
