Sick 'Bota
Discussion in 'Chainsaws and Power Equipment' started by T.Jeff Veal, Jun 13, 2020.
  1. T.Jeff Veal
    I've replaced the wheel bearings on the right front side on the 3130 twice. The left side went out, but looks like more damage was done...:picard:...don't know who wouldn't stop to fix it, even after they had gotten the parts for it...:whistle::whistle::zip:...
    Anyway, the outside race spun in the housing, and it has some wear on the end of the axle. 0613200621.jpg
    Both bearings failed... 0613200621a.jpg The new bearing seems to fit tight in the housing.
    Asking my mechanic/machinist friends for advice... SKEETER McCLUSKEY Screwloose
    Buy new housing and axle or see if it can be fixed?
    Boogeyman, eatonpcat, Maina and 8 others like this.
  2. Screwloose
    In this case I'd say green locktite would probably work. Also I'd wonder why the cage is failing, dropping a piece let alone a ball in the works would be catastrophic.
    Ou812, Steve Billak, Maina and 9 others like this.
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    same here as Screwloose ....clean with acetone then green bearing retainer...they usually arnt a super press fit anyways. maybe just dress up the end of that axle a little.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Buy a can of this activator for the retaining compound. It speeds cure time so you can put it back in service 20200613_095424.jpg
  5. brenndatomu
    What they said...I'm a fan of the primer too.
    Yeah, weird you are having these failures...it's not like you ever overload the front axle...:whistle: :D
    Maina, Barcroftb, Chvymn99 and 7 others like this.
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Its usually from heavy bucket work like brenndatomu said,I've changed dozens of them,the last one I did for a landscaper had an oversize bucket on it.
    dgeesaman, Maina, Chvymn99 and 8 others like this.
  7. T.Jeff Veal
    Not meee:whistle::whistle:
    1/2 face cord of green oak shouldn't be too heavy...:picard:...
    Or a couple 28" and 35" oak logs...:dex:... IMG_20191203_094839112.jpg 0420200951_HDR.jpg It has been a great tractor, 2006 model, only 3rd time replacing wheel bearings...
  8. Screwloose
    Do some searching to se if you can get lucky and find either a spherical caged roller bearing or a ball bearing with a higher ball count
    farmer steve, Maina, Chvymn99 and 6 others like this.
  9. T.Jeff Veal
    Ok, any suggestions on where to look?
    Maina, Screwloose, Chaz and 1 other person like this.
  10. Chaz
    Chaz
    Southwestern NY
    Jeff, you have something to measure the bore, Outer Diameter, and width?
    Does that bearing have a part # on it?
    I kinda know a place that deals with bearings
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    dont try to reinvent the wheel .....
  12. Screwloose
    Geez, put me out of business will ya. A major portion of my work is reengineering failure prone machinery to make it more reliable.
  13. Screwloose
    Looks like Chaz has a lead for you. Bearings are a commodity item and OEM's rarely put the best bearing available in. A good bearing house armed with dimensions can contact manufacturers directly and tap into their engineering department. Yours looks like cage failure and heavy duty cages are available.
  14. Chaz
    Chaz
    Southwestern NY
    Yep.. Considering I work @ NES Bearings, I think we can work something out.
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Well I was gonna say they may have been under engineered seeing how I change /replace so many of em
  16. Screwloose
    In that case it's a profitable part of your business.
    Chazsbetterhalf, Chaz, Maina and 3 others like this.
  17. Screwloose
    Ya gotta lotta balls working there.
  18. brenndatomu
  19. T.Jeff Veal
    Cool
  20. T.Jeff Veal
    We got it farther apart last night. It is ugly in there. Pieces of race, retaining cage are everywhere in the lower unit. Going to replace the other bearings too. I learned a VERY EXPENSIVE lesson... 3516.jpeg 3517.jpeg
