  1. savemoney
    Cold, wet blar... Running the stove a few hours now and then to keep the damp and chill out. Hope we don't have another wet June.
  2. mithesaint
    mithesaint
    NW Ohio
    Finally did the end of year cleaning. Finished the year with a bag count of approximately 253. Far and away the most I've ever burned, although I've only burned through three winters so far.
  3. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    Sitting around with the front and back door open in shorts! Lovin it. I have an old storage shed/kid's playhouse in the yard I'm tearing the roof off of and turning into a greenhouse next weekend, can't wait.
    savemoney likes this.
  4. mithesaint
    mithesaint
    NW Ohio
    Ugh. It's 10:30 at night, and it's 88 degrees here. I was tired of winter, but this is a bit excessive. I saw 96 on the thermometer here today. Thankfully the humidity isn't too bad, but it's still pretty miserable.
    Today was Day 1 of a 2 day project to replace my central air. Of all the nights to not have central air...it had to be tonight. Thankfully I still had an old window unit tucked in the shed. The bedroom is comfy, but the rest of the house is sweltering.
    DexterDay likes this.
  5. DexterDay
    That sucks.. It was Hot today. But the payoff will be worth it. :)
    Good luck on the help with your furnace ;)
  6. 343amc
    343amc
    Northeast Lower Michigan
    We got just under 4 inches of rain today. Woke up at 3 AM and it was almost nonstop thunder and lightning for 2 hours.
    Apparently I've got a flashing problem around the chimney. At least that's what the puddle on the kitchen floor this morning told me. I see a trip up to the roof in my future.
  7. savemoney
    Ugh! Wife watched the news. Weatherman said temps into the 30's and 40's tonight. You got it. The stove is running. June 20th is a bit late for temps in the 30's. :confused:
  8. badbob
    badbob
    40's,thundershower downpours last 3 days,stove running.A bit late even for out here!Gonna be nice upcoming week,though I gotta work.
  9. mithesaint
    mithesaint
    NW Ohio
    Dodged a bullet yesterday. One of my outdoor faucets is in a bad location at the back of a flower bed, so I have to use a leader hose. The hose that I used last year and so far this year was an older hose that had new connections that I had put on. I was getting ready to go to Lowes yesterday, and I heard the sound of water running. Turns out the connection had come apart, and the water was on full blast. I noticed this 5 minutes before leaving, and was gone about 2 hours. I'd hate to see the mess if I hadn't been there shortly after it happened. It probably only ran for 5 minutes or less. :yes:
    savemoney and gbreda like this.
  10. imacman
    imacman
    Denver, NC
    Damm global warming. :hair:
  11. badbob
    badbob
    Warm now,stove off,windows open,fixed window in one truck and 2 new batteries in camper,think I am going to call it a day and get a beer,as I am faceing a week of 10 hr days!
  12. badbob
    badbob
    Icepacks increasing at both poles,temps down for last 30 years,polar bears so overpopulated canada my have a special season!Most people do not realise we should be getting warmer as we are coming out of a little ice age!Too much worry,grab a brew.
  13. will711
    will711
    Pocono Mts.
    Have more than 1 , I know I did today :D:drunk: :drunk:
    Ward8512 and smoke show like this.
  14. mithesaint
    mithesaint
    NW Ohio
    Swapped out the worn out Briggs for a new Harbor Freight Chonda engine on the tiller today. I don't know why I didn't do that last year. Such an easy swap, and it starts and runs great. We'll see how long it runs for.
    Also put together my new sprayer for the lawn. The clover is taking over. Time to fight back. I don't mind a little clover here and there, but my lawn is almost white when it's time to mow.
    savemoney and smoke show like this.
  15. smoke show
    smoke show
    Pittsfield, Wi
    Got 3 Chonda 6.5hp in my fleet. Start easy and run smooth and quiet. Just don't store them with ethanol gas in the carbs.
    Whatcha spraying clover with? I spray 2,4-D and it don't do much for clover.
  16. mithesaint
    mithesaint
    NW Ohio
    I have a big jug of 2, 4 - D and am planning on mixing it heavy. I know it won't clear the clover completely, but I need to figure out the sprayer first before I dump an expensive jug of Trimec in it. Gotta sort out pressure, speed, etc. Was going to do it today, but it's too breezy and I'm having my Geospring installed and don't have water at the moment anyway.
    smoke show likes this.
  17. smoke show
    smoke show
    Pittsfield, Wi
    Here's a little cheaper option, but doesn't control crabgrass. http://www.tractorsupply.com/en/store/gordonsreg;-amine-400-2-4-d-weed-killer-1-gal
  18. mithesaint
    mithesaint
    NW Ohio
  19. Lousyweather
    Lousyweather
    Hot, humid, hurricane coming up the coast to mess with us on the 4th. No central air, but Ive got a window-mount A/C sitting downstairs in the basement to install....problem is, I am WAY to cheap to run it, so there it stays (got it fer free)....freaking bear tore down my birdfeeder again, things so used to humans I can practically pet it, and Ive got a ground bee nest to take care of later tonight......
    Oddly, pellet and stove sales are brisk, even in this heat......wonder what happens this fall/early winter? (This is a reminder to you procrastinators out there....remember Feb '14?)
  20. gbreda
    gbreda
    NH
    Same here, a bear as taken down the bird feeder many times this spring/summer. In past years if this happened once, I could take in the feeders for a few days and bear would move on. Not this year-Ive seen and chased it off several times on top of the other times I havnt seen it. So now the feeders may not go up much until Fall/Winter. I did find out that a neighbor was inadvertently feeding it but his 2 brothers read the riot act a month or so ago and told him to stop feeding the deer/turkeys. Maybe Mr bear will move on now.
    Mr bear better watch it and not get too cozy 'round here. Many of my neighbors are hunters (some with small children) and its not uncommon to hear gunshots in the area......
