Splitter Tire
Discussion in 'Chainsaws and Power Equipment' started by Grizzly Adam, Jun 27, 2014.
  1. Grizzly Adam
    Grizzly Adam Guest
    Got my 22 ton Speedco/Huskee splitter back in April or so. On the way home, the right wheel fell off due to the castle nut not being properly torqued. Well today Singetreau came to pick it up and he got two miles down the road when he found the same tire shredded. What the hell? Is this connected to the original problem? The tread looks good, all the wear is on the walls. What do you guys think happened?
  2. rookie1
    rookie1
    Air pressure low? I doubt the wheel falling off had anything to do with the tire shredding. Most tire failures are from low pressure.
    concretegrazer and Oliver1655 like this.
  3. cory@owen
    cory@owen
    Small trailers like those and boat trailers are bad about eating wheel bearings. Just don't stand up to highway speed. Maybe take a look at them. That can cause tire wear. Often they just lock up.
  4. clemsonfor
    Did the bearings fall out when the tire fell off when the castle nut came off?
  5. Grizzly Adam
    Grizzly Adam Guest
    Yes, I don't think they were ever properly set until disassembled, packed them with grease and reassembled.
  6. clemsonfor
    I figured they would have to but thought maybe there was a bearing unit pressed to the rim or something?? Never know what those crafty chinese can come up with.
  7. Grizzly Adam
    Grizzly Adam Guest
    Roller bearings on inside and out. Poor assembly at store.
  8. HDRock
    Sounds like a bearing get wasted, or the tire went flat or both
    Does the wheel spin properly now?
  9. Well Seasoned
    That sucks. Id rather put the splitter into a trailer rather than tow it. Every bump made me cringe. Good luck!
  10. Grizzly Adam
    Grizzly Adam Guest
    There it is, does mot spin freely yet not locked up.
  11. nate
    nate Banned
    Palmer, AK
    Most of those splitters aren't really made to be towed. Max speed of 40-50mph.
    I have towed mine a few times and I hate doing it. Can't even see it behind the truck or even tell if it's still there!
    clemsonfor likes this.
  12. Grizzly Adam
    Grizzly Adam Guest
    Yeah, never had it over 40. I don't like that it is completely invisible behind the truck.
  13. campinspecter
    campinspecter
    14 " tires , 3500 lb spindles and bearings , no springs only 8 psi in the tires to give things a bit of a suspension.
    Still eats bearings!
    And of course Woodwidow having fun splitting kindling!:thumbs:
  14. coal reaper
    coal reaper
    Nj
    • Splitter tire. No bearings required.
    jetjr, swags, concretegrazer and 3 others like this.
  15. Oliver1655
    Oliver1655
    Central Missouri
    Mine is built with a 7,000 mobile home axle with springs using 14 ply tires. 70 mph, no problem.
    concretegrazer, clemsonfor and HDRock like this.
  16. clemsonfor
    Never seen a MH going 70mph!
    HDRock likes this.
  17. Oliver1655
    Oliver1655
    Central Missouri
    Maybe not but my splitter has - Plus! :whistle:
  18. Grizzly Adam
    Grizzly Adam Guest
    All fixed up now. Split the little pile of maple from my neighbor.
    HDRock and Well Seasoned like this.
