Torchin' tarps
Discussion in 'The Wood Pile' started by fishingpol, May 3, 2020.
  1. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Just a quick post on how I top cover. I use a standard 6' x 8' brown tarp from big box orange.
    Set it out on the driveway.
    There are four grommets top and bottom. I take my mapp torch and run it lengthwise top to bottom at the two middle grommets to make three sections. It melts quick, sometimes a little catches fire, but I just stomp out the little flame. No cutting with a knife needed, no fraying along the edges.
    The edges seal really well.
    One tarp makes 24' long by 24" wide. A few heavy stones or cobblestones and they don't go anywhere. They are easy to manage since they just cover the top.
  2. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
  3. Ronaldo
    Ronaldo
    Torch is a great idea. Never would have thought of that.
  4. jo191145
    Torch does a much better job than I would have thought. Nice!!
  5. Well Seasoned
  6. fishingpol
    fishingpol
    Gotta share the ideas!:yes:
  7. amateur cutter
    That is absolute genius! Never would've come up with that. Thank you!
  8. Mwalsh9152
    Mwalsh9152
    Pelham NH
  9. buZZsaw BRAD
    Simple, inexpensive and ingenious. FHC backyard engineering at its finest. Three thumbs up! :thumbs: :yes:
  10. Maina
    Maina
  11. brenndatomu
    Great idea.
    I bet a soldering iron would do the trick too...
  12. JJP in Ohio
    JJP in Ohio
    Pickerington, Ohio
    fishingpol , how do you connect the 3 pieces together?
    Really cheap way of getting 24' of stack coverage! :thumbs:
  13. Gpsfool
    Gpsfool
    U.S.A.
    Kudos! Great idea
  14. fishingpol
    fishingpol
    Grommet set maybe? Overlap the ends and set two new grommets?
    Maybe even melt them together with a torch on low?
    Chazsbetterhalf likes this.
  15. moresnow
    moresnow
    The brown box store firewood tarps wont last a year here. Way to much wind. Good for drying!
