So... back to tarping the top stack of dried wood
Discussion in 'The Wood Pile' started by dotman17, May 1, 2020.
  1. Backwoods Savage
    Read this: Primer on Woodburning by Backwoods Savage
  2. Backwoods Savage
    To begin with, I can really see no sense at all in covering a wood pile then uncovering it until it rains then covering it again. Once covered, I see no sense in uncovering the pile unless it is to get wood from it to burn. It will dry excellently even though it is top covered. But, of course, don't cover the sides; just top cover.
    Also, everyone will find sooner or later that something hard and flat on top of the pile will work much better than any tarp. One exception could be the rubber roofing but even that can cause some problems unless you put something hard and flat under it.
    Over the years we found the absolute best way for our wood piles is that we cut wood in winter, split and stack in spring and then top cover it in the fall or early winter. Then leave it alone until you are ready to burn it.
    Some might get tired of seeing some of our wood piles but here comes a few more pictures:
    2015 moving wood.JPG Christmas-2008b.JPG Christmas-2008d.JPG Wood-3-4-10c.JPG Wood-2009c.JPG
    MikeInMa, Midwinter, milleo and 14 others like this.
  3. Screwloose
    on my stacks I use the rope over the top with a weight on each end technique.
  4. Stinny
    "Some might get tired of seeing some of our wood piles but here comes a few more pictures:" ... :picard:... can't get nuff pics of those stacks Dennis... :thumbs:
    And yup, I top cover too.
  5. dotman17
    dotman17
    Snohomish, Washington
    I usually let them dry all summer and then put a top tarp on in mid September. Let the inner plant dry out but then keep the surface dry going into the winter. It's whatcha gotta do I think up here in the PNW.
  6. Backwoods Savage
    Some day you might get tired of buying tarps though. For sure you have to keep things covered there too.
  7. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Top covered as soon as stacked. I use heavy stones every 3 feet or so and the wind doesn't really disrupt them. The tarps are cut to just the width of the splits. I hate them, but until I build a wood shed, they work fine.
  8. Dumf
    Dumf Banned
    Topless always until close to snow time. Never use tarps, never. Hard tops or that thick heavy rubber roofing/
    The locals here say that leaving the stacks open in rain, wind, and sun "drives" the sap out for drying. Seems to work well.
    Hate tarps that blow off, smother the splits, and look ugly....ugly.
    Get to know builders and carpenters for ply or OSB pieces.
    Forgot that 4+ cords are in an front and sides open wood shed. The rest stacked nicely :stack:
    out by species and age. Got wood ? I will often stare at the stacks and sniff.
  9. dahmer
    dahmer
    Ellwood City PA
    My method is the same as Backwoods Savage, split in spring, stack, top cover in fall. If I get bonus wood I leave the rounds stacked until the following spring to split.
  10. Slocum
    Slocum
    North Central Indiana
    The belting is working great for me.
    MikeInMa, FatBoy85, milleo and 8 others like this.
  11. NH mountain man
    NH mountain man
    WMNF N.H.
    Never, keep em' coming!
  12. Skier76
    Skier76
    CT and SoVT
    I leave the stacks uncovered until the snow flies. Before that happens, I use some metal roofing my neighbor gave me. I was using old rubber roofing material. It was a challenge to work with. The metal is a lot easier; put on top, weigh it down with a few rocks; done. The challenge there comes with keeping it horizontal as you start to burn the wood. The sections I have are a good 10' in length. Suppose I could cut them down!
  13. buZZsaw BRAD
    I had the opportunity to garb some belting like that last year and kick myself for not doing so. HEAVY stuff so i think that was my reason at the time.
  14. Backwoods Savage
    Well, the locals are at least parcially right. Sun and wind is what is needed for drying but rain????
  15. Backwoods Savage
    NO. You just cant take off of one end. Depending on how much you take off the stack, it is good if the covering is left with a slant down to take the rain/snow off the top and away from the wood.
  16. Dumf
    Dumf Banned
    Seems to do the job Dennis. Theory that rain "replaces" or "pushes out" the sap, then sun and wind dry the splits. It's worked for us for decades, only like you, covering in late Fall.
    P.S. How are you doing physically ?
  17. Backwoods Savage
    Physically is not good right now but it will get better. Thanks for asking. For sure it will get better if the hospitals decide it is okay to get back to some surgeries as I need one bad.
    fwiw, after hearing from some others on this forum a while back (quite a while) I went backwards and cut some wood, split and stacked it but did not cover it. Yes, it burned as expected. Shoot, I can get green wood to burn so why not. But what I can saw without any doubt at all is that although it burned and burned okay, in no way did it come close to the same btu's as we normally get. The fires certainly never lasted as long. And although I do my best to not be lazy, I can see no sense in working harder that is necessary. I'll let the sun and wind do their jobs but not the rain. Oh yes, some of our wood gets rain as we normally don't top cover until late fall or early winter but that short time won't do much harm at all plus during the time it is uncovered, the stacks shrink. In short, we usually stack to 4 1/2' and by the time we top cover the stacks are down to 4'. Then we top cover and forget about it for a couple of years. All is well.
    Slocum, Midwinter, Dumf and 7 others like this.
  18. Juniper Hill
    Juniper Hill
    Washington state
    Hey neighbor. I'm in Edmonds. I top cover as soon as stacked and go back and forth in the spring/summer when its raining and not. I use 6mil plastic and staple the 4 corners then release one end and restaple when I cover again. How do you do yours?
  19. dotman17
    dotman17
    Well, I've got stacks out there that I leave exposed throughout the year. If there are tarps still on the stacks in late spring because I didn't need to burn them, I take the tarp off for the summer. I then usually put a top tarp on them for the fall/winter -- which means I try to get as deep into September as I can get. I am short on firewood this year because I did not tarp enough even though it's super seasoned. It's just a sloppy mess. Six+ months of wet will do that to you. If I have a hot fire brewin' then no problem. But once you have a hot fire, that's never the problem. The problem is I need the wood dry enough to start a hot fire -- and if I don't tarp -- then it's useless to me. Yes, I've bought that expensive kiln dried ripoff crap at the stores to get the fire going and then put some of that sloppy mess but it's not worth it. At that point, I just turn my pellet stove on.
    So I try to cut/buy my splits and stack in the dry days of late winter/early spring (it's a great time to go over to central Washington and get some chopped wood from the orchards) and then stack them. I leave them exposed throughout the spring and summer or more. Often I'm a year+ out so it's at least 15 months. That's plenty for the indigenous species. Obviously the more the better but you can season Douglas Fir, for example, in like 6-8 months with a good summer -- and its ready to be burned.
    In short, I top tarp dry stacks I think I'm going to need for the season in late September. Repeat process.
    Juniper Hill and FatBoy85 like this.
  20. FatBoy85
    FatBoy85
    Washington State
    Seems like many of us PNWers have same issues if a wind break isn’t possible. The top of the stack is always an issue because it’s usually the driest wood that possibly got wet, the most accessible. Any wind will seem to blow some of this roof traction matting I have as well. It works ok but I know I would favor EPDM more than this for its flex in heat while staying in place because of its weight.
    I had heard of people here just screwing some down past the first few inches of the stack sides instead of adding splits on top. After that it was all about moving the screwed in split on each side over on the stack, work your way down a bit all along the stack. Not just the side you’re on. The more evenly you break down the stack overall, the longer it will stay dry and not lose its stability, crashing down in a heap in the middle of a rainy November night as you curse out the wind in so many different expletives... :whistle::wacky:.
    Midwinter and Juniper Hill like this.
