Flagpole mounting bracket
Discussion in 'The DIY Room' started by MikeInMa, Apr 16, 2020.
  1. MikeInMa
    I'm needing to get a new flagpole bracket that mounts to a tree. No problem.
    Except, I'd like to not screw it into the tree.
    I'd prefer to screw it to a 2x4, and then fix the 2x4 to the tree using a strap, of some sort.
    Tne strap I have in mind, is along the lines of a long radiator hose type of clamp. This way I can take the whole thing down, as needed. Also, it prevents the tree bark from "consuming" the bracket.
    I need a strap of 42".
    Does anyone know if such a thing exists, or, if there's a different kind of strap-type device. I was looking online, and nothing was popping up. I'll keep searching, using different search criteria.
    I suppose bungee cords or ratchet straps would suffice, but I'm looking for something less visible.
    *edit. I could zip together multiple long zip strips. Not sure how tight they'd hold the 2x4 in place. A little wobble is acceptable.
    TurboDiesel and Chazsbetterhalf like this.
  2. brenndatomu
  3. MikeInMa
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Why not a steel cable you can spray paint brown? You could use a turnbuckle to tighten. You can buy cable by the foot at most hardware stores. Lots of hardware for cable too.
    Good luck
  5. brenndatomu
    Yes, you can hook multiples together...but it says it goes up to 20" diameter...so that is 60 long, you said you needed 42"...which just happens to be the minimum for these too...
  6. brenndatomu
    You can buy that SS band material in a roll, make them any length you want...I've seen them 20' long before...
  7. MikeInMa
    Hmm.. interesting. The cable would be wrapped around the tree. So wouldn't the turnbuckle. Right? If against the tree, the turnbuckle wouldn't be able to tighten, unless there's a type I'm not aware of. Off to search for turnbuckkes.
  8. Warner
    Big zip ties.
  9. MikeInMa
    I'm now also thinking about how velcro straps would work.
  10. TurboDiesel
    If you have a sheet metal shop they can sheer strips of metal. They use strips to hang duct work from rafters.
  11. TurboDiesel
    We use a bander for banding skids of concrete forms snd 2x4's on the construction site. Know anyone that does commercial construction that would bring you banding and crimps/crimper?
  12. MikeInMa
    I do not.
    My objective(s) are to keep it simple, inexpensive, and something that can be removed easily and put back..
    Stringing zip ties/strips together, or, velcro straps, I think would be a solution.
    All good options. Keep them coming.
  13. TurboDiesel
    Ratchet straps
    :handshake:
  14. Sandhillbilly
    Sandhillbilly
    North central Nebraska
  15. MikeInMa
    Just wire? Pulled tight and twisted?
    Chazsbetterhalf likes this.
  16. Sandhillbilly
    Sandhillbilly
    Yep
  17. Sandhillbilly
    Sandhillbilly
    Can’t get much cheaper easier and rusty wire won’t show up much
    Chazsbetterhalf and MikeInMa like this.
  18. brenndatomu
    ...'til you find it with your Stihl wire finder...:whistle: :rofl: :lol: o_O
  19. MikeInMa
    While wandering around HD, I found some 48" cable ties.
    I'll see how they hold up in wind and sun.
  20. Warner
    :usa:
    MikeInMa likes this.
