Wood splitter question
Discussion in 'Chainsaws and Power Equipment' started by creek chub, Apr 14, 2020.
  1. creek chub
    creek chub
    Va
    I have a fairly new county line 25 ton splitter, purchased early January. Today I moved the splitter and it wasn’t on a level surface and hydraulic oil would squirt out every once in a while. The filler cap side was slightly lower than than the other side if that makes sense.
    Is this something I should be concerned with?
    thanks
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Make sure it's not over filled. Other than that, no. It's best to have the splitter level when possible. Hydraulic oil expands when heated, which happens when you use the splitter. That's why you don't fill the tank above the fill line or over its rated capacity. It also enters the tank fairly rapidly when using extending and contacting the cylinder so some turbulence occurs. The filler cap is also the breather for the tank that is necessary because the oil level changes constantly in the tank as the cylinder moves.
  3. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Check the level of the hydro oil and add as needed. Mine has done that to me once. I guess they need to be level.
  4. Screwloose
    no, everything is fine. When the cylinder retracts all the way in the fluid level rises to its highest level. When tilted lower they will spray.
  5. farmer steve
    farmer steve
    top of the hill york co. PA.
    Keep the fill cap to the high side if your not completely level. More level is gooder.
  6. creek chub
    creek chub
    Va
    Thanks for the replies. It is due for a filter change so I’ll check everything out. Never done a filter change though so hopefully it goes well
  7. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    :BrianK:The fill cap has a very small vent hole in it so if it's off level some a bit may squirt out. If it happens check you hydro level and try repositioning the splitter a bit. Maybe use a felling wedge under a tire.
  8. chainsawsoldier
    chainsawsoldier
    NE Kansas
    Nothing to be concerned with. If the full side is lower it can come out. Using it in the summer can also make it squirt more, as the fluid expands more. I leave a later of sawdust and chips under the splitter to adsorb the oil that comes out.
  9. TurboDiesel
    Over filled if still coming out when close to level. Nothing to worry about
  10. brenndatomu
    If you are just changing the filter, pick the splitter tongue up and stand it so it's sitting on the butt end of the beam...that should allow you to swap the filter without losing too much oil...I'd still have everything ready to go and try to be ready to be quick about it if the oil level is still high enough to want to run out...have a pan under it, but really shouldn't lose much at all...
  11. TurboDiesel
    If you're just changing the filter, probably won't need to add any more hydraulic fluid
  12. farmer steve
    farmer steve
    Make sure you get the right filter. My TSC tried to sell me the wrong one. Check the speeco website for your correct one. I'll get you more info when I get to the putr.
  13. Erik B
    Erik B
    Western Wisconsin
    This is how I had my Speeco when I changed the filter. Didn't lose any oil.
  14. farmer steve
    farmer steve
    My TSC splitter has the filter that has a integrated bypass on it.
  15. bigfrank
    bigfrank
    NorCal
    Good tip. I can't remember. Is the filter interval 50 of 100 hours?
  16. Erik B
    Erik B
    Western Wisconsin
    I don't know. I have changed the filter once in 20 years. I guess it is about time I do it again.
  17. jmb6420
    jmb6420
    I changed mine after the first 20 hrs and then annually after that.
  18. creek chub
    creek chub
    Va
    Do you lose much fluid changing it elevated like that?
  19. Erik B
    Erik B
    Western Wisconsin
    Practically none. I may have had a small pan under it when I first removed the filter. I may have lost the oil that was in the filter.
  20. Screwloose
    The filter does not need to be replaced anywhere near as often as you think. A splitter does not produce contamination like you would find in a engine. Cut open the filter and look in the pleats and you will find next to nothing. As long as the oil has no water in it your good for several years.
