Dead ash down.
Discussion in 'The Wood Pile' started by farmer steve, Apr 14, 2020.
  1. farmer steve
    farmer steve
    top of the hill york co. PA.
    I had this big dead ash in my fencerow but was in no hurry to drop it because of all the other wood that's been coming my way. Something didn't look right so me and the 261 took a ride. It just missed my neighbors grain head. Need the bigger saw and longer chain to drag it over on my side.
  2. Backwoods Savage
    Why is not the 261 big enough? It can handle a lot. Shoot, people were always amazed with what I cut even with a 290.
  3. farmer steve
    farmer steve
    That broken end was 22" across. Only have 18" on the 261. Like they say in TX. Bigger is better. My 290 saw a lot of big wood action before CAD struck.:hair:
  4. Horkn
    Cut from both sides;). Can do 36" tree then.:thumbs:
    JoeinO, Screwloose, MikeInMa and 5 others like this.
  5. Backwoods Savage
    Well, that is no reason to not use the 261. The bar does not have to be as large as the diameter of the log. Shoot, I've cut many 30" and up to 32" trees with a 290 using a 16" bar; not a problem at all and no, I do not cut some from one side then go to the other side. I cut all from the same side. Simple and easy. I remember when logging many times not using anything more than a 25" or 28" bar; no problem.
  6. Backwoods Savage
    Do not have to cut from both sides. Stay on one side of the log and it will do just fine. In Steve's case he could easily use a 16" bar.
    One can also remember that with a shorter bar, you get more power from the saw so you really don't lose anything by using a short bar.
  7. Andyshine77
    Andyshine77
    Cincinnati, OH
    True a larger saw in not needed. But if he has one I see no real reason not to. big saws make quick work if set up right, the reach so you don't have to bend over is also a plus. Run whatever you want to.
  8. buZZsaw BRAD
    Mine too :saw:
  9. Horkn
    Same here, but mines an 029 super. Close enough, but it's cut a ton of wood. Several tons actually;)
  10. buZZsaw BRAD
    the super has the same CC's as the MS290...56.5 The 029 is 54cc. You the original owner of your 029?
  11. Horkn
    It's an 1127 series saw, just like the others. But, the 029super has more power than the 290, despite the same CC's. All of these series saws really wake up with a muffler mod, so I hear. These are all held back with a restrictive muffler. I do like the quietness of the 029s compared to the wail of my dolkita. That thing is loud.
    My dad bought it new in 2000. Or was it 99? I went with him to buy it. It's mine now though.
    I used it the other day to cut up a down ash branch. I started it up after it sat for a couple years the other week. Fresh gas and 10-15 pulls and it was running like new.
  12. Backwoods Savage
    You are right about the muffler mods Horkn and the best guy I know for doing the mods is huskihl and he's done lots.
  13. MAF143
    MAF143
    North Central OH
    I'm a HUGE fan of Muffler Mods. Easy, low cost method of getting some added performance and also letting the saw run a tad cooler from what I understand. I know they made nice differences on my saws.
  14. farmer steve
    farmer steve
    The other half of the ash came down last night. I had been hoping a good wind would take it down but it didn't happen the other night but I guess the wind weakened it enough for gravity to help. It did take out a little bit of my Indian corn. Looks like more cutting in the heat.:mad:
  15. dahmer
    dahmer
    Ellwood City PA
    From the looks of that trunk i’ld much rather have the wind take it down rather than put a chain to it and then have to run.
    mat60, Midwinter, Horkn and 4 others like this.
  16. farmer steve
    farmer steve
    I have it marked where the barbed wire is.:hair:It is actually pretty solid but I'm glad it came down the way it did.
  17. dahmer
    dahmer
    Ellwood City PA
    Honestly, i’ld rather have barbed wire than have the trunk turn into a hand grenade.
  18. farmer steve
    farmer steve
    Figured mid 70's temps wood be good for cleaning this tree up. WRONG!T-shirt is soaked. Needed to get it out of the way as it was interfering with me spraying the Indian corn. Just about a 1/2 cord. 20200821_112228.jpg 20200821_122908.jpg 261 and 462 got the call.
    Midwinter, brenndatomu, mat60 and 7 others like this.
  19. dahmer
    dahmer
    Ellwood City PA
    You got a lot done for a “deceased” guy. You get that straightened out?
  20. dahmer
    dahmer
    Ellwood City PA
    Any idea on this year’s GTG?
