Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. The Wood Wolverine
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Customer...."can you port my 372?"
  4. M2theB
    M2theB
    Central Massachusetts
    Curb Alert, hadn’t worked in years.
    Fresh fuel and some tuning.
    I’m sure that’s barn dust. Under the hood is showroom.
    Probably should have a carb job and new fuel line. Ran a half tank through it cutting bittersweet along the edge of the field.
    Did ok in a 14” spruce round.
  5. kas
    kas
    Shelton Ct.
    Modded 1954 Homelite 17
    mr.finn, Fifelaker, Hoggwood and 10 others like this.
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  8. T.Jeff Veal
    This ol' gal was at my local shop the other day. 0407201008.jpg 0407201009.jpg
  9. M2theB
    M2theB
  10. Hoggwood
    Hoggwood
    Southern BC
  11. dahmer
    dahmer
    Ellwood City PA
  12. XXL
    XXL
    Ontario, Canada
  13. Hoggwood
    Hoggwood
    Southern BC
    LOL - Not too bad. I never run more than a couple or three tanks to fill up my truck. The XL-76/130 series are pretty smooth, all things considered. The XL-1's were the "bare bones" models and without the rubber wrap on the front handle, vibrate some. Nothing like the Poulan SD25A's though. The Super Mini's with rubber front/rear wraps are nicer though. I run a lot of saws without AV. But, it is the follow up splitting of the green, stringy Doug fir that leaves the mitts a bit buzzed.
    First outing for these both after I had them apart. They ran pretty well.
    Super XL-130
    XL-1
    JB Sawman, Fifelaker, thistle and 4 others like this.
  14. Hoggwood
    Hoggwood
    Southern BC
    Soft spot for the old Homelites. They are certainly easy to come by out in BC. Often in good shape and on the thrift. I enjoy "rescuing" them.
    Super44, JB Sawman, Fifelaker and 5 others like this.
  15. buzz-saw
    buzz-saw
    Ct.
    OH Yeah !!
    I can relate to this.
    Good to see someone else knows how to use a sun-dial
    Brandon Scott likes this.
  16. T.Jeff Veal
    Yes sir. The shop owner, Nathan, told me he got it running for the customer last year, put that bar and .404 chain on it. Guy took it home, and let it sit up. Brought it back this year, said it wouldn't crank. Nathan said it had spider webs all over it, gas still in it...he got it cranked, but clutch is froze up.
    Brandon Scott and M2theB like this.
  17. M2theB
    M2theB
    This one needed the double whammy. Fuel line was cleaved, never found a filter, and the metering valve filter in the carb was clogged with disintegrated fuel line.
    Put a little muffler mod on it and it’s a nice little yard saw!
    27A2337F-16FC-4418-BE54-12A720E78E4F.jpeg FBF3E3C1-8F90-4E9D-8D00-A6A078EB46DB.jpeg
  18. HolsatiaRedneck
    HolsatiaRedneck
    Schleswig-Holstein
  19. The Wood Wolverine
  20. PlumbSplitter
    PlumbSplitter
    Bayville NJ
    Heres my 450 Rancher Easter morning. Its my first real saw. Huge difference from my craftsman.
