241 decomp valve
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, Jun 22, 2014.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    The 241 has had almost 4 gallons of mix run through it and the chain is almost ready to replace. I had the top cover off last night cleaning the saw off and checking the air filter. Anyway, I noticed a dark oily sawdust build up around the decomp valve. Might this indicate a leak in the valve? I have not used the valve and don't see a need for it.
    I checked the decomps on my 390 and 440 and there is some saw dust around them but it isn't oily.
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Clean it well, run it and then check it again.
    HoneyFuzz likes this.
  3. foragefarmer
    foragefarmer
    Central, Virginia
    Done minus the running. It is going to be worked hard on Monday. Cutting 2200' of oak fence boards off the posts in order to go to the reclaimed flooring company.
  4. Boog
    Boog
    Where my spirit is free
    The chain almost needs replaced after just 4 tanks? What are you cutting, how many times has it been sharpened?
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Spend $3 and replace the valve with a plug, no more problems with leaking.
  6. Guido Salvage
    Guido Salvage
    I had to read that twice, he indicated 4 GALLONS have gone through the saw. With a 12.5 oz. tank that would equate to more than 40 fillups.
  7. Boog
    Boog
    Ahh, thanks Guido, I totally missed that! Makes sense now! :loco: :crazy:
  8. Anvil
    Anvil
    NE Wisconsin
    I would love to know your take on that saw after that much run time. Real user reviews are very valuable. So, if you could it would be very much appreciated!
  9. foragefarmer
    foragefarmer
    Central, Virginia
    Sorry guys, yep I would guess 30-40 fill ups since I got it a month or so ago.
    The saw is fantastic. It has been seeing up to 3-4 tanks full on some days. Really light in a practical sense. I was using an MS 250 and when I was cutting fence post tops with it my arms would start burning after 30-40 tops. The burn doesn't start till 50+ with the 241. I think part of it has to do with the better AV. I have not cut a bunch of firewood with it but it flew through white oak up to about 10".
  10. foragefarmer
    foragefarmer
    Central, Virginia
    If it is leaking, that was what I am going to do. I don't really understand why it is on there.
  11. DexterDay
    X2.. On a 40 cc saw (even up to 60 cc) I wouldn't use it.
    Plug it..
  12. MasterMech
    Clean it and don't use it for awhile. If it still leaks, plug it.
    4 gallons thru a 241 is a good bit of run time. Especially in such a short period of time. Been using the snot outta that one eh? o_O:thumbs:
  13. Boog
    Boog
    I got mine a couple weeks before you, and its still begging me to put a 3rd tank through it. :emb:
  14. foragefarmer
    foragefarmer
    Central, Virginia
    Ran 4.5 tanks through it today. And bought two chains.
    MasterMech likes this.
  15. MasterMech
    Were they PS3? What did they get ya for those?
  16. foragefarmer
    foragefarmer
    Central, Virginia
    Here is what the saw looked like after I was done with it.
    They were PS3. "What do they get ya for those?" Not sure what that means. Price?
    concretegrazer likes this.
  17. DexterDay
    Holy Chit! ! You sure have used that little booger!
    Does it run as expected? How does it compare to your 025/250 it replaced?
  18. MasterMech
    That's funny, I have a local firewood cutter (semi-commercial) that runs both a 250 and a 241 as well. He likes the 241 a lot better!
  19. MasterMech
    Yup, just curious on the price.
  20. foragefarmer
    foragefarmer
    Central, Virginia
    I bought files and oil as well so not exactly sure on chain price.
    It is a great little saw! :thumbs: Only minor thing is it starts hesitating a fair amount time before it actually runs out of gas when you are working it hard. First time it did it I was WTF? but now I know what it is when it starts. Could be just the fuel pickup on this particular saw?
    That and the useless decomp valve.
