Maple score and thoughts on spalting
Discussion in 'The Wood Pile' started by rainking63, Apr 2, 2020.
  1. rainking63
    rainking63
    Old Lyme, CT
    Got one hell of a load of maple from a guy in town here. I've already taken about 8 cords of red oak from him, and he asked me if I wanted some chunked up maple that he had stacked behind his shed. It was cut last May, and I said sure!
    Got it home (in about 12 loads in my tiny pickup) and have been trimming it down and splitting what I can. A lot of it is good, hard wood that the moisture meter shows at about 22%. Some of it, especially closer to the bark, is showing some spalting. Just curious here: how far to you let that go before you throw it out? Is it worth trying to keep it dry until this season or am wasting my time?
  2. mirnldi
    mirnldi
    Top covered that will last for quite awhile. If you want to get rid of it I’ll be right over.
  3. Woodwhore
    Woodwhore
    Mason NH
    Oh ya, your good
  4. billb3
    If/when it gets really soft and easy to stick a screwdriver in and super lightweight it doesn't burn very long.
    I have some that was stored in rounds a little too long. Some of it isn't very good firewood.
  5. T.Jeff Veal
    That probably won't burn in a hi tech northern stove. Need to send that down to GA, where we burn scraps and spalted wood...:tractor:...:coldfire:
  6. rainking63
    rainking63
    Old Lyme, CT
    If by "Hi tech northern stove" you mean "Old leaky smoke dragon" then I guess I'll throw them in there.
  7. JPDavis
    JPDavis
    Prescott, AZ
    Looks fine to me. I wouldn't think of throwing it away.
  8. buZZsaw BRAD
    Knock the bark off that you can and it will stay longer. Scored a PU full of sugar maple last September. It was bucked and left in a stack from the May 2018 tornado here in New Haven county so 16 months and it was starting to go bad. I processed it right away and it was still good for the most part. IMG_0894.JPG IMG_0893.JPG
    Yours looks just fine. Great score BTW!:thumbs:
  9. Fanatical1
    Fanatical1
    Your good to go.. Keep it dry as you can under cover and it will be ready to burn this fall most likely.
    I've had worse...
  10. T.Jeff Veal
    I figured you had a cat stove, shucks, missed my chance for some hard maple...
  11. Backwoods Savage
    You have absolutely no concerns with that wood! It is prime and you can burn it next winter with no problem. The only requirement is to stack it off the ground and then top cover it. Then forget about it until next fall.
  12. Slocum
    Slocum
    North Central Indiana
    I come across a lot of spalted hard maple. You are good to go.
