Dishwasher What level of Clean ?
Discussion in 'Everything Else (off topic)' started by Chvymn99, Mar 29, 2020.
How do you load your dishwasher?
  1. Pre Clean (wipe down)
  2. Just Run under hot water?
  3. Just stick it in there and let it go?
Results are only viewable after voting.
  1. rottiman
    I'll give you the velcro mitts...........................:rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
  2. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Wow! We sure have come a long ways!
  3. rottiman
    No time for you to become "sheepish" over it now...............................:rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
  4. Chaz
    Chaz
    Southwestern NY
    Chazsbetterhalf does the dishes, I do the cooking. We/I installed one per her request.
    It does OK, we generally rinse off our plates after eating, so there's not much dried on food anyway.
    Not sure if it's the best money ever spent, but she's happier.
    :D
    Eckie, rottiman, Chvymn99 and 6 others like this.
  5. 343amc
    343amc
    Northeast Lower Michigan
    I rinse them off before putting them in the sink, then put them in the dishwasher. I can’t stand nasty dishes sitting in the sink.
    When I redid the kitchen we got a GE Profile dishwasher, and it does a pretty good job unless you feed it something like a crock pot that has caked on residue on the sides.
    The dishwasher that was in our old house when I bought it was an early 80s vintage Kitchen Aid. The one just moved chit from one dish to another. It was less labor intensive to wash them by hand.
  6. Jack Straw
    Jack Straw
    Ours works great but I’m not getting off the recliner to see what brand it is, it’s that kinda day!
    Eckie, rottiman, farmer steve and 4 others like this.
  7. brenndatomu
    Get to thinking about it...one thing that we (I) do that may skew my results to the positive, is that dishes usually go into the sink right after dinner and just the process of washing hands, rinsing out a dishrag to wipe the table, countertop, stove, etc, runs enough water (usually warm) onto the dishes that after "soaking" like that for an hour or two, things generally are pretty much liquefied and the dishwasher has a pretty easy job to do...
    Eckie, Chvymn99, yooperdave and 2 others like this.
  8. brenndatomu
    Just holler for the wife to go check...:whistle:
  9. Jack Straw
    Jack Straw
    She says it’s a Bosch, it does a great job and it’s quiet!
    Eckie, rottiman, farmer steve and 5 others like this.
  10. brenndatomu
    Wow...you actually got away with it, huh? :jaw: ;) :rofl: :lol:
  11. Jack Straw
    Jack Straw
    She knows we are discussing it here, she’s a good sport! She has to be! :thumbs:
  12. brenndatomu
    Eckie, farmer steve, Chvymn99 and 5 others like this.
  13. Woodwidow
    Coldwater wasn't very good at his job. Cricket doesn't leave a plate alone until only the finish surface is left.
  14. wildwest
    Chvymn99 , do you have a newer washer with electronic controls? Ours from 2014 is. Normal cycle sucks (1:15 hours), bottom sprayer only and it uses so little water that it never gets hot (water in pipe is between washer and heater is cold), bottom rack gets pretty clean but coffee cups still have rings inside and leaves crumbs on the other stuff on top rack. I have to manually program it for both upper and lower sprayers, temperature boost, and if I want to use the dry cycle that all ends up taking 2:56 cycle. Yes, 3 hours o_O I do 99% of the dishes and prewash, WWW does not, his loads are hit and miss if they come out clean and I usually have hand wash the silverware because the dry cycle baked the cheese or whatever is on them. Ridiculous to use 3 hours of electricity to save a gallon or so of water.
    I miss our old dial start washers and the old detergent. Like 40 minutes and dishes sparkly.
  15. brenndatomu
    I'm certain that nobody on FHC needs to be told to make sure things are not stacked in too tight...to the point where water spray can't hit the dishes/etc...if water spray can't hit it, probably not gonna be clean...
  16. Horkn
    You have to use good detergent. In addition, use a cup of vinegar in the top tray. Simply take a bowl, ramekin, etc and put a cup in it right before starting the washer. The vinegar is a great trick that my wife found years ago. It makes a huge difference if you want clean dishes.
  17. metalcuttr
    metalcuttr
    western WA
    Our Washer is a 2014 ish Kitchenaid That does a fair job if you pre clean which I do all the time. We have a wand with a soap reservoir and a scrubber pad on it that I use. Unfortunately my Wif just rinses and racks. The load may stay a long time before it gets big enough to wash as there are only two of us. This allows time for a rinsed only dish that my have something sticking on it to dry. Those dishes need extra attention after the dry cycle. Speaking of dry cycle, I agree that stupid energy saving dry cycle is the dumbest thing ever! Those older washers blasted water like a fire hose inside and completed a cycle in about an hour. Dishes were hot to the touch on completion. Bad news for a plastic dish close to the bottom heat element but good otherwise in most respects.
  18. metalcuttr
    metalcuttr
    western WA
    Another problem with dishwashers is they tend to become a storage unit if you don't quickly move the dishes to the cabinets. I have told the Wif that, next time we remodel the kitchen, I am going to leave the pantry for food but rip out all the cabinets and just leave the sink and two dishwashers. One for the clean and one for the dirty!
    Eckie, Chvymn99, brenndatomu and 2 others like this.
  19. farmer steve
    farmer steve
    top of the hill york co. PA.
    This could get long. We installed a new DW when we remodeled. The first load was almost as dirty as when we put them in. Manual says maybe less soap. That didn't work. Finally called the co and repair guy came out. Nothing wrong. After the 3 rd call we exercised our right to a new machine. Got it no better. The 4th and different repairman looked at it a said you have hard water and it will never get your dishes clean. Put a water softener in an the dishes are sparkling clean. That one finally died and we got a new kitchenaide. Mrs. FS likes the 1 hour wash to save water and doesn't like the results. I just got a compliment the other day on how clean the dishes were. Yes dear,hi temp scrub,sanitize rinse and dry. Takes a while but I like a clean plate although cold water (Callie) does a pretty good job.
  20. rottiman
    At least we got that from a credible source....................................:rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
