I'm gonna need more room.
Discussion in 'The Wood Pile' started by stihl sawing, Jun 16, 2014.
  1. stihl sawing
    stihl sawing
    Arkansas
    Probably will wait till about then, right after deer season. only problem is I can't get back in there with the truck when it gets wet. I done got all the easy stuff. these will require some serious 4 wheel drive to get out with and maybe some winching. I may try to get the ones closer in a few days, it's still pretty wet back there. those are kinda bottomlands.
    Stinny and Backwoods Savage like this.
  2. Backwoods Savage
    That definitely can be a problem. For us, using the atv and an atv trailer works good. Most times in early December there isn't much frost so having the wider tires on the trailer is a helper. I'm wondering if the ground freezes much down there?
    stihl sawing and papadave like this.
  3. stihl sawing
    stihl sawing
    Arkansas
    The ground don't freeze here much and if it does it's never a deep freeze.
  4. stihl sawing
    stihl sawing
    Arkansas
    But i'll be honest, I'd rather cut that stuff in 100 degree heat than freezing temps.lol I don't mind sweating but I hate sweating with winter clothes on. Last year I cut two days in 105 heat. Long as I keep drinking Gatorade and water I'm fine.
    papadave, Woody Stover and HDRock like this.
  5. Backwoods Savage
    I'd rather wait for cooler air. We also start right after deer season. Nice thing here is that if I sweat too much (rare then) it is not far from the house and I can change. But usually have to wear the Carhartts so when I get warm, the Carhartt comes off or is unzipped and that usually works fine.
    stihl sawing likes this.
  6. Gasifier
    That must have been quite a storm! Nice score! Agree with Dennis. Winter cutting is great. Just have to get it before too much snow.
  7. stihl sawing
    stihl sawing
    Arkansas
    We rarely get snow, it was a doozy of a storm too. thought my place was going. can't believe the trees in my yard didn't go.
    Gasifier likes this.
  8. GrJfer
    GrJfer
    The Woods of Arkansas
    Mother nature did the dangerous part putting them on the ground, now all you need to do is C/S/S.
    As for covered storage, top cover it. It won't rot away.
  9. HDRock
    Wow,, you're going to have a lot BTU'S their to burn some time when it's ready, good for you
  10. savemoney
    I would show you a pic of the cellulitis I got from my tick bite but it is too gross. With No amount of exaggeration, it was the size of a football on my very fat belly. I felt like I was on fire. It hurt so bad I was punching things in a rage. Then I was sick, weak, etc. I had to take the antibiotics twice because the first time it didn't best it back. Now have arthritis. Can't prove that came from the infection, but it could have. If the wood can wait, then please consider waiting. Those damm ticks have the upper hand in that environment.
  11. WeldrDave
    That's a "SWEET" score! I'm like you in a sense, I don't mind cutting when it's hot, "BUT" I have to agree with the gang on the tick issue….. If you get lymes, you'll never forget it!:eek::(. Spray, spray, spray:)
  12. Woody Stover
    Woody Stover
    Southern IN
  13. Backwoods Savage
    Wow. That stuff is nasty for sure.
  14. stihl sawing
    stihl sawing
    Arkansas
    Well I went a cut one of the tree blowned down. Got three loads out of the tree. the last five chunks were hollow. It was very hot, I started feeling it about one o'clock. Got back to the house on the second load and it was 97. I waited till later to go get the third one. First load here. SANY1436.JPG
    thewoodlands, HDRock and Gasifier like this.
  15. stihl sawing
    stihl sawing
    Arkansas
    what I had left. and the second load, didn't get a real full load cause of the heat. I needed to recooperate.lol The 036 pro became a noodle monster at this time. SANY1437.JPG SANY1439.JPG
    HDRock, papadave and Gasifier like this.
  16. stihl sawing
    stihl sawing
    Arkansas
    SANY1438.JPG SANY1440.JPG What I had left after the second load and the final load. I didn't realize it was that hot. By the third load I was one exhausted puppy.
  17. Gasifier
    That is hot. Too hot for me to be cutting in. Nice work though Stihl!
  18. stihl sawing
    stihl sawing
    Arkansas
    I should have not gone back right after lunch, but it's done now. time to move to another tree., which is right beside the one I just cut.
    HDRock and papadave like this.
  19. WVhunter
    WVhunter
    Mountains of WV
    Nice job! :axe:
  20. cnice_37
    cnice_37
    Its like oak hell and hoarder's heaven.
    I hate the heat, give me 30 degrees and some dry gloves and I can cut all day. 80+ and I'm quitting in a few hours.
