initial carb tuning
Discussion in 'Chainsaws and Power Equipment' started by bocefus78, Jun 18, 2014.
  1. bocefus78
    bocefus78
    Got my 180 carb swap done. I have both screws out 1 turn.
    It pops on first pull and will only run for a second after that. Does the l screw need to go in or out and how much?
    This is a wal bro Wt215 fwiw.
  2. HDRock
    I would turn it out some
    Turn Out more fuel , turn in less fuel ,about 1/4 turn at a time
    Idle should be turn in for faster idle
    Pallet Pete likes this.
  3. cnice_37
    cnice_37
    If you can.... just feather the throttle to keep it going and start turning L one way or the other.
    I tend to lean out L to get the engine to start racing up to keep it running, then you can usually stop playing with throttle and keep it going.
    1/4 step in either direction until it runs should also get it done without blipping throttle.
    Scotty Overkill and HDRock like this.
  4. MasterMech
    It should run on the fast idle position even if the L setting is off a bit. Will it stay running at wide open throttle?
    If it only dies at idle, then I would crank the LA adjustment in a few turns and get it running. Then back the LA off until you get a normal idle, adjust the L for best RPMs and throttle response, then set the LA for your final desired idle speed. Then you get to do the H side.
    If it won't run longer than a second or two regardless of carburetor adjustments or throttle position, you either have a big air leak or you're not getting impulse signal to the carb (fuel pump not working).
    HDRock likes this.
  5. DexterDay
    What they both said..
    Turn it in a little, once running, you can fine tune. :)
  6. bocefus78
    bocefus78
    I can make it idle now sporadically but not forever. Any throttle results in it dying pronto.
    Thoughts?
  7. Scotty Overkill
    I always turn my screws out 3/4 for initial start-up on a rebuild. Then richen/lean them as needed.....sounds like you may have the L screw out a tad too much possibly......let us know what you find.
  8. cnice_37
    cnice_37
    This is where I'd go with 1/4 turns on L. Start in one direction and take mental notes, then do the same opposite direction. Once running, dial her in.
    I see you mention 2 screws.... Is this a fixed H jet?
    Where do you have LA set?
    I'd go towards lean to get it running, so LA goes OUT and L goes in.
  9. MasterMech
    LA has no effect on mixture, only speed. ;)
