Large Pile of Sawdust on bottom of wood pellet stove! Is it termites or carpenter ants?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, May 22, 2014.
  1. don2222
    don2222
    Salem NH
    No
    The squirrel cage room blower was full of sawdust, so I pulled it out and saw a mound of sawdust! Maybe that is why there was sawdust all over the carpet?
    Looks like a bad Nylatron Auger Bearing? The auger does wobble around in the bearing plate hole.
    Has anyone seen this?.
    See pic
    Older Merkle-Koriff auger motor in a Whitfield Advantage Plus
  2. badbob
    badbob
    Trick question?
    slvrblkk likes this.
  3. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    Sounds like the lower auger plate bushing, or what else others may call it....
  4. don2222
    don2222
    Salem NH
    No, I have not seen this happen on a Whitfield before and wanted to know if anyone else has seen this happen?
  5. don2222
    don2222
    Salem NH
    Yes
    I have a couple of bearings on order. It may be a good time to "Pimp the Auger" - check for burrs and "Auger Pox" and install a brand new high quality Gleason-Avery auger motor?
  6. mike holton
    mike holton
    Old Dominion
    fines
    SmokeyTheBear likes this.
  7. don2222
    don2222
    Salem NH
    Hi Mike
    Yes fines. What type of bearing does the 25-ep stove have?
  8. mike holton
    mike holton
    Old Dominion
    on the auger? doesn't have one , its direct drive straight to the shaft, we have a cast sleeve which fits over the feed tube and a heavy rubber grommet between it and the motor itself to seal it up. no need for a bearing
    http://www.englanderstoves.com/manuals/25-EP-EPI_Combined.pdf
    check page 48 of this manual for the exploded view of the auger and motor assembly
  9. don2222
    don2222
    Salem NH
    Oh, yes, thanks for refreshing my memory. I have worked on a few and sold 2 new ones. I only replaced 1 auger motor so far. They are pretty rugged machines! I like them. :)
    Therefore the 25-EP relys on the bearing in the auger motor. Smart Design. Why have two bearings? LOL
  10. mike holton
    mike holton
    Old Dominion
    yeah, unless you are going to float the auger in the tube a second bearing is overkill. we do it with bottom feed units but its not necessary for top feeders if the feed system is well thought out
    jtakeman and RockyMtnHigh like this.
  11. Lousyweather
    Lousyweather
    yea, looks like fines to me have migrated thru the bearing.....termite and carpenter ant leavings are different, from what ive seen
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Stop feeding it fines.
