Split Second Kinetic Log Splitter
Discussion in 'Chainsaws and Power Equipment' started by smoke show, Jun 19, 2014.
  1. smoke show
    smoke show
    Pittsfield, Wi
  2. nate
    nate Banned
    Palmer, AK
    The 2 handed operation looks to be a pain.
    Pallet Pete, Hedgerow and papadave like this.
  3. cnice_37
    cnice_37
    Price?
    If I were to buy a flywheel splitter, it would be a Super Split.
    The 2 handed thing could be defeated and I'm sure 99% of owners will.
    Last guys to venture down this path didn't do so well, so I certainly wouldn't be the guinea pig and would bet on the sure thing.
    rookie1 and Hedgerow like this.
  4. papadave
    First thing I noticed too nate.
  5. MasterMech
    Price will be the determining factor. Coming from Agri-Fab, I'm betting it will be less than a Super Split. ;)
    Every demonstration for these splitters shows them running 12" or smaller rounds. I'm all for showing off the best attributes of the machine but the majority of us run bigger wood than that and the horizontal only/no lift design would not work for me in the vast majority of what I bring home. (18" and up!)
    Trilifter7 likes this.
  6. lukem
    Works good when splitting veneer quality rounds. I don't see it working on my gnarly hedge rounds where my 22 ton is in granny gear for 75% of the stroke.
    I like to see how it would have handled this gem:
  7. cnice_37
    cnice_37
    Granny gear, love it... that must be like stage 3? :thumbs:
    rookie1 likes this.
  8. lukem
    Its the high pressure, low volume, bog the motor stage.
  9. HDRock
    Apparently they have a log lift accessary
    At 1:00 mark
  10. Hedgerow
    Hedgerow
    SW Missouri
    The SS handles Hedge pretty well..
    Don't know what the new kid on the block is made of though..
  11. BrianK
    BrianK
    West central PA
  12. lukem
    It did it. Walnut is pretty easy stuff, even the crotches.
  13. MasterMech
    I want to see it eat a round with a 10" limb/knot coming off the side. If everything I processed was something I could reasonably lift, then one of the kinetic machines would make a lot of sense. And for more than one of you guys, perhaps they do. But there is a reason I own a chainsaw with a 36" bar....
    That lift is manually operated. I have never tried one but I can't see it being "easy" to get something 24" + up on the splitting bed. The machine is almost certainly limited in the size of the rounds that it can efficiently process without undue strain on the operator. This where the fast hydraulic machines shine. No definite limit on the size of the rounds you can process, vertical capability, and with a little technique and know how, very little speed penalty on the smaller stuff.
  14. DexterDay
    For most of what I encounter, one of these kinetic splitters would do the trick. :)
    One day... When I can actually stop buying saws....
  15. BrianK
    BrianK
    West central PA
    Is it American made or a Chinese knock off? That's what I want to know.
  16. Fanatical1
    Fanatical1
    I have the same reservations on the large knotty rounds. I guess if you can own a half dozen saws, what's wrong with owning two splitters? :eek:
    Hedgerow, MasterMech and HDRock like this.
  17. HDRock
    I have to bust up my big ones to lift them up and put them on my 7 ton so the next splitter will be horizontal vertical all in one unit, with no extra crap to drag out and set up.
    Having to use two hands on that splitter to cycle, is not cool either
    That accessory lift they have looks kind of flaky but then again, that set up with that lift might fit some people's needs perfectly.
    The price point will make or break it probably
  18. Stinny
    OK... fly wheel, fast, no 2 hand lever operation... how about this little feller... ?
    rookie1 and concretegrazer like this.
  19. HDRock
    Those things are crazy and no lift either
    Stinny likes this.
  20. clemsonfor
    That looks perfectly safeo_O
    Stinny likes this.
