got chain grinder set up again
Discussion in 'Chainsaws and Power Equipment' started by yamadog, Mar 12, 2020.
  1. yamadog
    yamadog
    pa
    got grinder set up again to try out able to reverse it time so hopefully no burr on left tooth
    Chaz likes this.
  2. chris
    some burring depends a bit on whose wheel you use- kinda a trial by fire type of thing as none post or print wheel specs other than size. some 20+ years ago I had a cbn type wheel -plated. I was not particularly impressed then. time change and I am sure they are much better now- course the price still hurts at apx $90-100 a pop. They do run a lot cleaner and no dressing required although a occasional cleaning with a boron stick is needed. You can't dress them down for those itty bitty pico and nano teeth though.
    somewhere around here i have a wiring diagram to make any of the single direction units bi-directional just need a dpdt ,co ( Double Pole Double Throw, Center Off) switch to make it work.
    Chaz, yamadog and Screwloose like this.
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    You need to get to looking! Post up for the fellow hoarders.
    Chaz, Screwloose and jtstromsburg like this.
  4. Nixon
    Nixon
    West Sunbury,Pa .
    upload_2020-3-12_17-51-0.jpeg This may help .
    Chaz, Screwloose and jmb6420 like this.
  5. Nixon
    Nixon
    West Sunbury,Pa .
    Chaz and Screwloose like this.
  6. Mag Craft
    On a chain grinder can you take a DPDT CO switch and connect it into the line cord and forget the Cap. The schematic shows the cap before the switch so I am thinking it was added to the circuit and not part of the existing motor or is it needed for phase shifting and if so then what size cap do you use.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    Would that capacitor not already be in the start circuit ?
    Mag Craft, Chaz and Screwloose like this.
  8. yamadog
    yamadog
    pa
    i was to stupid to do it i got it to switch directions but not full power both directions so to it to shop to do it but still had put a switch to shut off or unplug to switch directions he couldn’t find a 3 pole switch that fit in where other switch was so i just wired a plug i can turn on and off
    Chaz likes this.
  9. Screwloose
    If you just want to try it in reverse you can use an air nozzle to get it spinning in reverse then switch it on. That flimsy burr doesn't cause any issues but the crap coming towards you sucks.
    Nixon and Chaz like this.
  10. Screwloose
    Try a wheel from Dynasaw I got mine from bailey's. If you ever wear it out just have it replated. And if you want a special wheel make your own body and have it plated in whatever you desire.
  11. Mag Craft
    Ok I get it now. The schematic is showing the existing wiring for the motor but with a DPDT CO switch put in place of the original switch. That would work.
    Nixon likes this.
