Oil boiler is leaking water intermittently.
Discussion in 'The DIY Room' started by Warner, Mar 7, 2020.
  1. Warner
    B4BD07EC-FD29-470E-A6C0-6FA12EB85AFB.jpeg Recently my wife said she heard a strange sound then noticed water dripping from the pressure relief valve. I have changed out the valve it didn’t change anything. I am wondering if the noise she heard was the bladder in the gray tank?
    My dad has this system installed about 10 years ago. The guy that installed it was a complete hack and now is out of business. No body wants to work on it as it’s a blue flame( whatever that means). Any help or info would be greatly appreciated.
    Horkn likes this.
  2. brenndatomu
    What's your system pressure at?
    Has it changed recently?
    What pressure is the relief rated at?
    Horkn likes this.
  3. stuckinthemuck
    stuckinthemuck
    Check your expansion tank to see what the pre-charged pressure is.. or If it has failed. Too low pressure or failed tank can allow extra water in the system making it susceptible to over pressure..
  4. Canadian border VT
    You probably know this but the areas with green moss on copper is where it’s leaking.. And I would probably rule out your pressure tank first. As they are designed to leak went over pressure
    Horkn likes this.
  5. Warner
    E28B2185-D032-405E-B1E8-E42FE2D6033C.jpeg So, the gauge is buried behind the expansion tank in a place where it’s hard to see...
    Horkn, stuckinthemuck and brenndatomu like this.
  6. brenndatomu
    That's a good place for it...:picard: :rofl: :lol:
  7. Warner
    I’m going to check the pressure in the tank
    ya, this is my life...
  8. Warner
    20 psi in the expansion tank.
  9. Warner
    Looks like the pressure gauge is reading slightly above 20 psi
  10. Warner
    Thanks, the one with the green moss is an issue but it’s not the one leaking on the floor.
  11. Warner
    Thanks for the help guys! I have a helper here at the moment working in splitting some wood if I don’t respond quickly it’s because I’m running the splitter.
  12. TurboDiesel
    Check the boiler feed valve to make sure the "low pressure" (cold) is normal, also.
    Im guessing the expansion tank is flooded
  13. stuckinthemuck
    stuckinthemuck
    Would water have come out of the valve when he tested the pressure on the expansion tank? I figured if the bladder failed, that would have happened.
    TurboDiesel and Horkn like this.
  14. Horkn
    Try to pinpoint the source of the leak. 20 psi is fine.
    stuckinthemuck likes this.
  15. don2222
    don2222
    Salem NH
    Hello
    Looks like a Buderus Boiler with the DHW tank under the boiler and probably the Buderus Controller. That is the normal install, just looks different, I have the Buderus boiler with the Tekmar Controller and Super Store 40 Gallon DHW tank with lifetime warranty. My DHW tank leaked at the bottom after 10 years so I got a new $1200.00 tank for $50 processing fee.
    I heat with wood pellets so I only use the boiler for the DHW in the winter because I buy the oil in the spring or summer when the price of oil is cheap. Then I have an ECO smart instant electric on demand hot water panel to heat the hot water in the summer when the electricity is cheaper than the oil,
    So check the bottom of your DHW tank for leaking due to it’s age.
    TurboDiesel and stuckinthemuck like this.
  16. Warner
    33751895-D683-4BE4-A654-9DE0C522B2FE.jpeg This pipe is where the water is coming from.
  17. don2222
    don2222
    Salem NH
    Easy to change that pressure valve (probably have to drain the boiler) or
    Put a pan under the pipe and wait for the heating guy to come. :)
    stuckinthemuck, Horkn and MikeInMa like this.
  18. Horkn
    Yeah that looks like that is it. Sometimes crud gets caught and it can't seal properly. A new one will be cheap and easy to replace.
  19. Canadian border VT
    He said he changed PR valve, yes boiler is Buderus blue I have one and love it.. because it causes me no problems...
    if he was in western NH I’d fix it for a truckload if dry wood;);)
    lil cousin is plumber west leb
    EDIT. How is new valve green??:sherlock:
    Horkn likes this.
  20. Horkn
    I thought I read that. Well, it's obviously leaking, replaced or not. Well unless it's something going over psi. If it goes over 30 ps ever, then it would do that.
