Poulan Pro 5020 is awesome!
Discussion in 'Chainsaws and Power Equipment' started by JJP in Ohio, Mar 1, 2020.
  1. JJP in Ohio
    JJP in Ohio
    Pickerington, Ohio
    I just wanted to say my new Poulan Pro 5020 performed
    flawlessly! I know it was just small apple trees, biggest stuff
    was 12-14" trunk sections, but it seems like the power is
    really good.
    Chaz, Woodsnwoods, XXL and 8 others like this.
  2. brenndatomu
    I have a whole pile of 4218's and 5020's...and about $300 in the whole pile...they have cut a PILE of wood for me...never owned anything else until a couple years ago...built a Farmertec "stihl" 660 and bought a cheap MS290 Farmboss since then too...
    Chaz, M2theB, Woodsnwoods and 7 others like this.
  3. JJP in Ohio
    JJP in Ohio
    Pickerington, Ohio
    My contact at Tractor Supply called me to advise they had this PoulanPro 5020 that
    was returned because it was too heavy. Used one day. We think they probably needed
    it to cut up a downed tree and then took advantage of their generous return policy!
    Normal price $199 and on sale at $179, he discounted it to me for $99. I couldn't afford
    not to take advantage of the deal. Full warranty included of course. I'm sure it will handle
    anything I might want to cut with it.
    Chaz, M2theB, Woodsnwoods and 5 others like this.
  4. Screwloose
    They seem to hold up quite well.
    Chaz, M2theB, Woodsnwoods and 2 others like this.
  5. bushpilot
    bushpilot
    Eastern Washington
    I have two of them. One has a hesitation that I cannot resolve, probably just needs a new carb. It just will not come off of idle cleanly to max RPM. Give it a few seconds, and it will get there.
    They are easy starting, and with a sharp chain, they cut fine. A little heavy for the size I think, but not drastic.
    Anyhow, for that price, it will serve you well. Last I looked, they could be had "reconditioned" on ebay for $129 or so, I would not pay more than that (though I did for my first one). They are surprisingly good saws for the price, but for $199 I would start looking at others.
    Since I got the 55cc Jonsered, the Poulan has been mostly sitting.
    Chaz, M2theB, Woodsnwoods and 4 others like this.
  6. Screwloose
    Quite a few on craigslist cheap. Most just need new fuel.
  7. brenndatomu
    3 things to try
    1. Run Startron in your fuel for a while...that will often clean it out.
    2. Try adjusting the carb then
    3. Replace the fuel line in the tank...they will crack and suck air...causes throttle hesitation while the crack is still small...
  8. bushpilot
    bushpilot
    Eastern Washington
    I have never heard of Startron, will look it up. So far adjusting the carb and replacing the line have not helped.
  9. Jim Stokes
    Jim Stokes
    Mobile, Al
    I have a strange Poulan 5020 problem! I bought two of them, and one developed a recoil problem at about a year, wouldn't rewind!
    I took the recoil assembly off, and it worked fine. Lubed anywhere that might rub, and it worked a couple of pulls, then no-go!
    Contacted Tractor Supply, and the Manager swapped it for a new one! Wow!
    Then, the other one has developed the same symptoms. Seems that the recoil cover doesn't have enough tolerance, so II even
    made washed to go on the screws that attach the cover. Still no go. Poulan says they never heard of it.
    Not fair to take it back to Tractor Supply at two years old.
    Ideas? I wonder if the plastic recoil cover shrinks with time, and binds.
    Next idea is to leave the cover off, and start it with a cordless drill!
    Chaz, Screwloose, M2theB and 2 others like this.
  10. brenndatomu
    I have 2-3 5020's, a couple are older too...but never had that problem...
  11. Mag Craft
    I have 2 5020's and never had a recoil problem.
  12. Mag Craft
    Congrats on your new saw for a pretty good price.
  13. bushpilot
    bushpilot
    Eastern Washington
    Two of them here, never seen that problem.
  14. moresnow
    moresnow
    My 5020 has seen some rather severe duty on occasion. It also gets used on plenty of easy stuff. I did feel like it needed ri chened up a bit initially. Minor adjustments. It's treated me fair and owes me zero.
    I do pull the recoil, clutch and carb covers almost every use to blow out the residue. It really gets full otherwise.
    Chaz, Screwloose, M2theB and 3 others like this.
  15. M2theB
    M2theB
    Central Massachusetts
    Just picked up a 3614 as a CL Curb Alert the other day. Was able to get it to run ok with just tuning, but just ok. I’ve never had a Poulan so considered it par that course.
    Dig into it further yesterday with the intent to replace the fuel line.
    Found that the fuel line was disintegrating in the tank and that was clogging the carb metering valve filter.
    Cleaned the carb and now it is a mean little saw. Strong in the cut.
    bushpilot, Chaz, brenndatomu and 2 others like this.
  16. Mag Craft
    That is a lot of crap in that carb. I am surprised it ran at all until you cleaned it.
    Chaz, M2theB and Screwloose like this.
