Friend / coworker needs a hand
Discussion in 'The Wood Pile' started by Chaz, Feb 23, 2020.
  1. Chaz
    Chaz
    Southwestern NY
    So, my coworker needs some ash dropped at his place. We discussed it in the fall, and they are/were doable with my limited skill set.
    He is not confident with his felling, so I said I'd help him out.
    Well, he goes through a chit-ton of wood every year. Along the lines of 16 full cord per year.
    :faint:
    So I spent the weekend up at his place.
    Dropped and delimbed 3 yesterday.
    These were the sketchiest ones as there are electric lines running to their barn.
    They have heat lamps on recently birthed lambs and a goat. So, these had to drop correctly so as to not take out the lines, or the clothesline posts.
    Second one laid on top of the first, with around 6ft left before the power lines.
    o_O
    Then a third one that had to be guided away from the shed.
    Some serious rot at the center of that one.
    Missed the shed by around 10 ft.
    Since they were across the driveway I helped delimbing them and move debris.
    So.. That's Saturday.
  2. BigPapi
    BigPapi
    The hills of Western MA
    Great job, Chaz! Your buddy is lucky to have you. Safe drops, no damage, baby animals don't have to sleep inside.
    I hoist a glass of Winning to you, sir!
  3. hovlandhomestead
    hovlandhomestead
    MN
    Awesome. That looks like some nice country there.
  4. Chaz
    Chaz
    Southwestern NY
    So.. after yesterday's fun, I awoke a bit stiff and sore in areas, but more needs done.
    So, today I go back and drop 9 trees, no delimbing today.
    :dancer:
    Only some fencing to to avoid.
    A 4 trunk that ended up in 3 different directions.
    There's 3 that I didn't want to tackle today, as I feel they require "guidance" but I can't get a rope over the branches due to height.
    Barcroftb or amateur cutter any recommendations on a "spud gun"??
  5. Chaz
    Chaz
    Southwestern NY
    A couple hinge shots.
    Critcisms/advice welcome.
    Not the prettiest, but they all did what I needed.
    So, I'm tired, sore, healthy, and drinkin smoothies.
    :cheers:
    One can do worse over the weekend.
    :thumbs:
    :saw:
  6. Chaz
    Chaz
    Southwestern NY
    Thanks BigPapi and hovlandhomestead
    :cheers:
    Was fun to do a bit of felling.
    Although I did find an issue with the Stihl, I haven't tore it apart for pics yet, will be seeking advice this week.
  7. Midwinter
  8. The Wood Wolverine
    Appears everything went where you wanted it. Good job. Your friend/coworker is fortunate to have your acquaintance.
  9. Chaz
    Chaz
    Southwestern NY
    I found out today rather unsurprisingly that the Poulan 4218 lacks the gumption for a bore cut.
    :picard:
    I do hope the issue on the Stihl is fixable, although heavier than the Poulan, it has horsepower to spare.
    :thumbs:
    After my reading here, I did bore cuts on all 3 trees yesterday, and I'm a fan.
    :yes:
  10. Eric VW
    Great job Chaz :thumbs:
    Safely on the ground, fingers and toes accounted for... that’s a win in my book!:salute:
    As for pucker factor, I’m sure there were moments. o_O
    Overall, I’d guess your coworker is probably awfully thankful, yes?! :yes: :handshake:
  11. Eric VW
    You are well aware of how big a fan that walt feller is of the bore cut....:thumbs:
    And several others too. :salute:
  12. Locust Post
  13. M2theB
    M2theB
    Central Massachusetts
    Nice job! Looks like a lot of fun, figuring which one goes first and where. As Eric VW put it, never lose that pucker factor.
    Smoothies on the house!
  14. dahmer
    dahmer
    Ellwood City PA
    When you lose the pucker factor you begin loosing common sense.
  15. dahmer
    dahmer
    Ellwood City PA
    By the way, 16 cords a year!!!!!! What’s he heating, a circus tent at 85*?
  16. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Good job Chaz.
    16 cords a year!? They have a winter house in the Artic?
  17. metalcuttr
    metalcuttr
    western WA
    Chaz That looks like a nice, competent job! Good on you to help!:yes:
  18. Chvymn99
  19. Chaz
    Chaz
    Southwestern NY
    Thanks everyone for the comments.
    :emb:
    Coworker was indeed quite thankful.
    He's got a large farmhouse that is in dire need of insulation.
    We've discussed it many times.
    Fortunately for him, he's had a tree service dropping off wood, but the main dropping area is currently inaccessible.
    For better or worse, these trees will be split and fed into his furnace within the coming weeks.
    :doh::picard:
    Not for naught however, he's got a very healthy stand of oak trees on his 50 acres, and I'm welcome to drop and take some.
    :thumbs::thumbs:
    Now I need more storage space.
    :faint:
  20. Well Seasoned
    Great work Chaz & great pictures! That'll be some primo wood!
