Oil the Splitter Beam: Yes or No
Discussion in 'Chainsaws and Power Equipment' started by buzz-saw, Feb 23, 2020.
  1. buzz-saw
    buzz-saw
    Ct.
    Here is a question for all you splitter guys here.
    Do you oil or grease the beams on your splitter.
    On my old machine I always put a little bar oil on the wear surfaces , I used bar oil because it was sticky and less apt to run off as fast as a conventional oil.
    I also know that some splitters have an actual grease fitting on the sides of the wedge or sliding push block ( depending on the design ).
    I guess there are two ways to look at this ; the oil will cause dirt and such to stick to bar but might help on wear and dry nothing sticks.
    What's everyone's thought on this and what do you do ?
    mat60, amateur cutter, Slocum and 9 others like this.
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I grease mine daily. The fresh grease forces out the dirty grease then wipe with a paper towel. Keeping it lubed with something will extend its life.
  3. jrider
    jrider
    No. Never. Not moving at high speeds
  4. buzz-saw
    buzz-saw
    Ct.
    As I thought , two ways to look at this.
    I have no grease fittings but could certainly add some.
    Not moving at high speeds but could be under pressure forcing the block on ram and beam to rub together.
    Don't know on this one. Thanks guys.
  5. Warner
    I don’t want grease on my firewood. I have put many cord through my huskee not a drop of lube with no issues. I don’t think it would hurt anything if you were to do so.
  6. Warner
    mat60, amateur cutter, Slocum and 5 others like this.
  7. jmb6420
    jmb6420
    I don't get any grease on the wood. Grease certs are on underside of the wedge ears. With my splitter design the main friction between the wedge and beam is between the bottom side of the beam flange and the top side of the lower wedge ears. [​IMG]
  8. Warner
    Interesting, what type of splitter is that?
  9. jmb6420
    jmb6420
    Northern Tool 37 ton
  10. M2theB
    M2theB
    Central Massachusetts
    I’ve got a Timberwolf P1.
    I hit the two fittings on the pushblock with grease at the beginning of splitting. Just once a day. While I’m there I put a couple pumps on the beam and spread it with a paper towel.
    I’ve never noticed grease on the wood, but always think there might be.
    I’m pretty sure I do it because it was the OEM recommendation
    Hasn’t hurt anything
  11. Warner
    I was picturing someone smearing grease on the beam where the round sits.
    mat60, XXL, amateur cutter and 9 others like this.
  12. buzz-saw
    buzz-saw
    Ct.
    On my old splitter with oil on the beam I never had an issue with oil on wood.
    Just wondered what others thought on this.
  13. Warner
    When I was first introduced to hydro splitting the old buck that let me borrow his splitter told me to pour oil on the beam. In my opinion it made a mess.
    mat60, amateur cutter, Slocum and 6 others like this.
  14. sirbuildalot
    sirbuildalot
    Mass
    When it was proven in another thread that the majority of members keep their splitters outside, I think greasing metal on metal areas becomes even more important. No reason not to do it. A couple dollar tube of grease would last several months greasing a wood splitter beam once or twice a week, and it takes less than 1 minute to do including grabbing your grease gun. There are a lot of “slow moving parts” that still require grease. Pretty much any axle, 3 point implement turntables, multiple points on loaders, etc.
  15. buzz-saw
    buzz-saw
    Ct.
    I never flooded it with oil to the point it was running off ; just a little and then spread it out with a chip brush or small paint brush.
    I am lucky that I have inside storage. My old splitter was never left out in the elements in all the years I had it. No doubt the new one will get the same treatment.
    Thanks everyone for your input on this.
  16. clemsonfor
    The guy who I cut with sometimes and I borrow his splitter does this. He pours used oil all over the beam. I smeared the beam and sides with grease when I borrowed it. The beam is pretty much wiped off from wood hunks that act like a wiper when stuck or just the attachment point of the wedge. The edges of the beam it sticks around longer.
    I never had a problem with oil or grease on my wood. Anything there soaks in as it dries and is such a small amount it doesn't matter.
    Sent from my moto g(7) using Tapatalk
  17. brenndatomu
    Been around a ton of splitters in my life...never seen one that had any oil/grease on the beam...other than from a leaky cylinder...
  18. Horkn
    Exactly. Grease or oil will collect crud and make it worse
  19. Horkn
    Our Didier splitter is older than a few members on FHC. No grease/ oil on the beam, still kicking after 40+ years
  20. Backwoods Savage
    I do put oil on the beam when I am finished splitting. It will dry off before the next use but the metal still gets the benefit. If you use grease, any dust will stick to the grease so I do not use it.
    Looked at the owner's manual, bingo. They say to use oil and not grease. Guess I'm doing okay.
    I always remember what Grandpa liked to say: "Oil is cheaper than metal."
