Cleaning advice
Discussion in 'The Wood Pile' started by jrider, Feb 17, 2020.
  1. jrider
    jrider
    I have a fireplace with a simple flue. I’ve paid to have it cleaned in the past but am looking to do it myself. Have had guys do it from the living room and go up into the chimney but they had some crazy vacuum. Also had guys remove chimney cap and do it for my roof which is very walkable. I’m looking to buy a brush kit and do it myself. Guessing from the roof and going down. What should I be looking for as far as equipment goes and how much should I be spending? Imagine I will be shopping Lowe’s or Home Depot
  2. sirbuildalot
    sirbuildalot
    Mass
    I’m assuming it’s just a clay flue. If it was a stainless liner I’d recommend a poly brush. If clay, I’d buy a steel bristle chimney brush that is the size or slightly larger than the inside of the flue tile. I’d measure your chimney height and get enough HD fiberglass poles to extend a couple feet past the top of the chimney. Usually the poles are around 3/8” diameter. I just saw some nice ones at Aubuchons. 5’ long and nice big 1/2” approx. thread ends. I clean mine myself several times a year. Saved lots of money. When you sweep it go up and down several times for a 2-3 foot section then move down and repeat. For a fireplace I’d tape plastic sheeting over the opening.
    FatBoy85, JoeinO, jrider and 5 others like this.
  3. dahmer
    dahmer
    Ellwood City PA
    You can however you think is best, but I would shop at Amazon for this. My buddy tried it and ordered one after he used mine. Flexible rod, run with a cordless drill. I bought a couple extra extension sections. B42C217D-BDC5-41A2-95A4-A5F9C51ADE1C.jpeg 783F5E51-1AB6-44EB-BE11-DBD1E0FA27A2.jpeg
    Ron T, FatBoy85, JoeinO and 9 others like this.
  4. jo191145
    Flexible rods and a wire brush the appropriate size. Won’t cost much.
    If you want to scrub the throat you’d want long handles wire brush. Maybe something made for a grill.
    Unless your burning wet wood there shouldn’t be much of a problem. Fireplaces burn relatively clean.
    Elvisss222, Felter, JoeinO and 6 others like this.
  5. Screwloose
    We've always brushed from the top down. Just add a section of rod scrub add another rod till we hit bottom. Then the shop vac is put outside with a long hose in through the window and we clean out the stove.
  6. BHoller
    BHoller
    Central pa
    As someone who cleans allot of chimneys I can tell you that rotary cleaners do a better job easier than brushes. It will also do a decent job of cleaning the smoke chamber. The only hard part is cleaning out behind the damper. Which isn't to bad with a decent vac.
  7. sirbuildalot
    sirbuildalot
    Mass
    I’ve never tried a rotary cleaner. Do they do just as well on rectangular flues? Are the rods flexible enough to make a 90 degree turn? If so I may look into it. It’d be nice to do it from the bottom.
    Felter, FatBoy85, JoeinO and 5 others like this.
  8. BHoller
    BHoller
    Central pa
    They do work well on rectangles. The only thing with square or rectangle is that you have to run each rod both directions to get complete coverage. The pro rods I use easily go through a 90. I can't comment on the soot eater because I have never used one
  9. Aje1967
    Aje1967
    Kenosha, Wisconsin
    This.
    Felter, FatBoy85, JoeinO and 4 others like this.
  10. Woodwhore
    Woodwhore
    Mason NH
    I clean mine from the bottom, once a year go upbrop and inspect
  11. buZZsaw BRAD
    I have an extra steel brush 8x12/9x13 size that uses ropes. You can have it as i dont use it.
    Felter, FatBoy85, JoeinO and 3 others like this.
  12. JoeinO
    JoeinO
    NEO
    I bought rods and a brush for my insert liner from a fireplace shop and probably over payed. I spray with this Rutland following their instructions.
    Just got up on roof a week ago. The first time I did it I couldn't turn the brush to be able to pull it back up. Realized the damper must be open.
    Took these before and after pictures.
    brenndatomu, Thor, jrider and 3 others like this.
  13. FatBoy85
    FatBoy85
    Washington State
    Is that the Lopi Medium insert??
    JoeinO likes this.
  14. The Wood Wolverine
    I use the rods and brush JoeinO posted pics of and they work great on my double wall ss. No way you’re going through a 90 degree. And it’s very difficult to switch directions while in the pipe. I have to go through one way, usually down from the top, then pull back out the top. I’m sure there’s better options for square/rectangle, that spinner looks good.
    JoeinO and dahmer like this.
  15. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I use a soot eater bottom up through the clean out ion my tile chimney. It will do a 90 degree bend.
    FatBoy85, JoeinO, BHoller and 3 others like this.
  16. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Bought one this fall at menards. They work great from the ground up.
    FatBoy85, JoeinO and dahmer like this.
  17. dahmer
    dahmer
    Ellwood City PA
    I showed it to my buddy because of his chimney configuration and because of his size, 6’6” 350 lbs. After he tried mine he ordered it and said, “I ain’t ever going back up on that roof.” I bought mine at Rural King but they were sold out. Never saw them there this year.
    FatBoy85, JoeinO and Ron T like this.
  18. JoeinO
    JoeinO
    NEO
    Not sure I just know it as a Lopi flush wood plus
    FatBoy85 likes this.
  19. JoeinO
    JoeinO
    NEO
    I need to do some research because I would love not getting back on the roof.
  20. FatBoy85
    FatBoy85
    Washington State
    I think they just changed the name a little bit even of the unit itself doesn’t but I have the Lopi Flush Medium Insert Hybrid-Fyre. Exact same face plate as yours. How do you like yours? I figure follow a bit of your advice on cleaning yours and that way I’m a bit more informed. The insert was installed last month and I thought I wasn’t going to be able to use it all that much, but I’m glad I’m wrong.
    dahmer likes this.
