Best way to get stove down stairs.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Warner, Feb 14, 2020.
  1. Warner
    New stove is in the garage, it’s final location is up one step then down a dozen. In the past I have called a few buds and we carried it down. Now nobody wants to come help when I ask! Lol. DABCD6EF-9466-46D8-9BF9-E36B6ABC2F54.jpeg I don’t think the slide will work out too well.
    FatBoy85, Lone_Gun, Horkn and 4 others like this.
  2. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Remove the slide, replace with 3 - 2x6 boards, tow straps securing the stove to your vehicle, one person back up slowly another person guide the stove (from the top/behind the stove) and lower to the basement. It'll work, did it with more than one appliance!
    Thor, Lone_Gun, Horkn and 8 others like this.
  3. Warner
    Unfortunately there is a garage where the vehicle would need to be to make a straight shot.
  4. Well Seasoned
    How close are you to Littleton? We've got heavy duty dolly's we use. One guy on bottom, one guy on top holding the dolly.
  5. Warner
    Thanks! 200 miles round trip. Do you know what brand they are?
  6. wildwest
    And take the door off and firebrick if it's easy to put back to lighten it some. Also I hired a place with a mechanical stepping dolly to get our gun safe down stairs.
  7. brenndatomu
    So nothing to anchor to up top? No door or window to run a strap through? 2x4 across the opening, tie a trucker strap to it, use that as your winch to lower the stove down the forementioned boards/slide...
    More pics of the area would help us help you...;) :yes:
  8. brenndatomu
    Once it is at the bottom, 2 wheel dolly, or 4 wheel cart for sure!
    Or rolling it leapfrog style on a couple pieces of 3' ish long pipe works well on concrete too...
    Chazsbetterhalf likes this.
  9. BHoller
    BHoller
    Central pa
    Probably an escalera. They are pretty much the industry standard stove cart. They have a power stair climber.
    Chazsbetterhalf and brenndatomu like this.
  10. Warner
  11. Warner
    Not having much luck finding one locally
    Horkn and Chazsbetterhalf like this.
  12. BHoller
    BHoller
    Central pa
    Yeah unless you are friends with a stove guy that probably won't happen
  13. brenndatomu
  14. BHoller
    BHoller
    Central pa
    I am sure you could anchor to that garage somehow then use a pulley to lower the stove down ramps
  15. Warner
    1C6F12DF-7D27-4BCC-8C4E-F1D62D8B4B25.jpeg Only issue I have with that would be getting it over the lip on the bilco
  16. Warner
    I suppose I could put a pallet in front of the lip.
  17. Warner
    Dad put a door for 2x6 construction in a 2x4 building. That might require some blocking so I don’t rip the door out of the wall!
  18. Warner
  19. Warner
    Thinking more about it the way the garage is built it may just pull the whole thing down:picard:
  20. brenndatomu
    This is a stove, not a truck...you may be surprised how little it takes to keep it from sliding down the boards.
    Setting it on a pallet in front of the Bilco lip is dead on.
    You will probably want one other person to help make sure things don't get hung up and slide down in a well controlled manner.
    FatBoy85, Chazsbetterhalf and BHoller like this.
