the mix thread
Discussion in 'Chainsaws and Power Equipment' started by splitoak, Jun 13, 2014.
  1. DexterDay
    Uh huh... ;)
    mdavlee likes this.
  2. bogydave
    Some think that less oil in the mix will improve performance.
    The oil in the mix, is the only lubricant the internal moving parts get, (gasoline is dry & has no lubricating qualities).
    Now 5% or 10% oil mix will smoke & lower performance, but
    32 : 1 probably won't be noticeable.
    With some of the new formulated 2 cycle synthetic oils.
    The new oils don't burn at the low temperatures like the older petroleum based oils do. Many of use remember
    the older saws with 30 weight oil mix,
    smoked a little all the time, it was considered normal.
    Smokeless oil, means it's not burning inside the combustion chamber.
    So if your saw don't normally smoke with the mix, then you notice it starting to smoke,
    it's running hotter than it should be, & is burning the 2 cycle oil.
    Time to let it cool & find the reason, (dirty/plugged air filter maybe ) :zip:
  3. GrJfer
    GrJfer
    The Woods of Arkansas
    We can thank the EPA for a lot of headaches we face day to day. Ventless gas cans, low oil mix, and the list goes on.
    I'm a believer in a little extra oil is a good thing. I mix about like bogydave does .9 or .95 gallon of fuel to 2.6oz of oil. Currently running the Stihl HP mix because of the extended warranty. Now a note on fuel and octane. My manual for the MS261 recommends 89 octane. I am lucky to have a few stations within 25 miles of me that have ethanol free fuel in all grades. If it were not available I would and do use startron http://mystarbrite.com/startron/
    HDRock likes this.
  4. nate
    nate Banned
    Palmer, AK
    True... and I like coming home after a day of cutting and not stinking of 2 stroke exhaust.
    I remember riding an old 74 Ski-Doo as a kid and my snow pants and coat would stink for days. It would fume out the house enough my Mom made us keep it all in the basement.
    I doubt that 40:1 would be really noticeable, but more oil than that I'm not sure?
    I mix my saw gas 5 gals at a time. 1 gal would have me running to the gas station almost daily while cutting.
  5. HDRock
    I mix in a 1 gal can from a 6 gal gas can, put the oil into a 2.6 bottle to measure and put in about .8 gal of gas, if screw up and put more gas than I wanted , I will add a little more oil, I don't worry about to much oil, I do worry about to much gas
  6. Cut4fun
    Cut4fun
    OHIO Redneck
    I mix mine 5gal at a time too for the 32:1.
    The 1gal can for cocktail mix for gtg's only in past. Then flush can. Now it is used to carry for small jobs where I think 1 tank isnt enough.
    1gal can is filled from the 5gal can. Also a couple of 2.5gal cans I use from the 5gal too. That way I just carry what I feel is needed.
  7. MasterMech
    Mixing 5 gallons at a time also reduces the error margin. Assuming you were mixing 50:1, if you're off .25 oz of oil in the mix you're only off 2% at 5 gallons (51:1) instead of being off nearly 10% at 1 gallon (55:1).
    Do the same while mixing, say Opti 2 or AMSOIL (100:1 oils....) with their little "pillow packs" that hold 1.6 oz of oil (80:1) and you could wind up mixing 95:1 instead of your intended 80:1.
    IHATEPROPANE and mdavlee like this.
  8. mdavlee
    mdavlee
    I usually mix 2 gallons at a time or sometimes 5 if I know I'll be doing lots of cutting. I can run through a couple gallons in 3 hours milling.
    Hedgerow and Cut4fun like this.
  9. MasterMech
    You guys mixing .9 gallons of gas to 2.6oz of oil are closer to 40:1 than you might think.
    128 * .9 = 115.2 oz of fuel
    115.2 / 2.6 = 44.3:1 Mix Ratio
    Because technically adding oil to your fuel reduces the octane rating a tad.
    Keep using the StarTron. Ethanol or not, today's fuel is junk and will not store worth a damm either way.
    clemsonfor and badbob like this.
  10. IHATEPROPANE
    IHATEPROPANE
    Do the saw manufacturers recommend the same mix throughout their lineup? Do they change the recommendations depending on how "professional" or "home owner" the saw is considered? Just curious.
    PS. I always go a tad heavier on the oil than recommended. I don't put a ton of hours on my equipment so it probably doesn't matter what I do ......
  11. splitoak
    splitoak
    jefferson co wv
    As far as i know stihl is all 50:1.....but im gonna start puttn a little more oil in my mix...;)
  12. bogydave
    Octane additive slows detonation & the gasoline burns a little cooler & slower, (less violent )Higher octane, slower the ignition,
    ( in micro seconds ) A timing issue for when the fuel will explode.
    Minimal effect the performance in a 2 cycle.
    Many/most brand name 2 cycle oils have fuel stabilizer in them.
    Not sure about Amsoil ?
  13. MasterMech
    Amsoil Sabre Pro does, not sure on the others.
  14. MasterMech
    There is no difference in the major lines from top to bottom. Does anybody know if Poulan still recommends 40:1 in some stuff?
    IHATEPROPANE likes this.
  15. mdavlee
    mdavlee
    Actually in other countries the 660 and 880 are recommended to run 25:1 even with stihl oil.
  16. thistle
    thistle
    Polk/Guthrie Counties,IA
    .I use 40:1 in everything including the vintage Mac's. Most all of my factory literature from the late 60's - late 70's calls for it.
    Oliver1655 and mdavlee like this.
  17. Hedgerow
    Hedgerow
    SW Missouri
    Ran a gallon of the Lucas mix today...
    Nuthin' blew up...
    Winning!!!
    Oliver1655, MasterMech, DSS and 5 others like this.
  18. Carbine
    Carbine
    Just don't let all the smoke out of the engine and you should be alright..
    Hedgerow and mdavlee like this.
  19. Jon1270
    Jon1270
    Pittsburgh, PA
    I'm no expert, but all this conflicts with my understanding of what goes on. I have assumed that, much like the output of our chimneys, smoke from the exhaust is evidence of the oil *not* burning, while the absence of smoke indicates complete combustion. This idea that smoke from the exhaust means that the engine is running too hot seems... well, totally wrong.
    DexterDay likes this.
  20. DexterDay
    This is my understanding as well.
    At idle or start up, most saws will smoke some (or any 2 cycle OPE) .
    But based on what I have read, when the saw is at running temp, the oil (well, some of it) is burned. But because of how a 2 stroke operates, there is always some fresh fuel that is mixed and sent out the muffler without being burned. But that is just how a 2 cycle engine operates. At a certain point in the stroke, the intake and exhaust are both open, and unburnt fuel gets out. But what is burned, does combust. Just takes a higher temperature to happen.
