No milling today
Discussion in 'The Sawyer Room' started by Ward Hoarder, Feb 8, 2020.
  1. Ward Hoarder
    Ward Hoarder
    West Virginia
    @#$& mice
  2. JB Sawman
    JB Sawman
    pennsylvania
    Hated to hit the like button on that one if you have a AG equipment dealer nearby check with them they make some stuff they put in the cabs of combines to keep the rodents out I forget what it is called I use nylon net wrap with moth balls seems to help although its tough to hold the moths still for the operation :rofl: :lol: good luck JB
  3. Chaz
    Chaz
    Southwestern NY
    :mad::mad:
    Had the same thing on the lawn mower many years ago.
    Not since we've moved here fortunately.
  4. Screwloose
    At least it's fixable. I hate mice !!
    T.Jeff Veal, Chazsbetterhalf and Chaz like this.
  5. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Does this require tweezers or just really small rubber bands and time? Trying to understand the whole process. Seems like it could be a great idea, if a guy can come up with enough moths.
  6. JB Sawman
    JB Sawman
    pennsylvania
    Tweezers and fingernail clippers :faint::rofl: :lol:
  7. JB Sawman
    JB Sawman
    pennsylvania
    Hey Ward Hoarder did you get your mill up and running yet ??
  8. Ward Hoarder
    Ward Hoarder
    West Virginia
    Parts are supposed to be here today. Ordered online. What's a good blade for locust/Osage?
  9. JB Sawman
    JB Sawman
    pennsylvania
    I have had the best luck with the 1.50 wide 10 degree Bi-metal on my mill I have the 17 HP diesel on my lt35 and with the lower horsepower it pulls that blade real good through locust I have tried the 7degree turbo and the new 747 blades I just do not seem to have enough horsepower to pull them I also found that the 10 degree double hard blades cut well in the locust but I only get maybe 200 bd ft out of a blade where I get 500-600 easily out of the bi metal one other thing cutting locust if they have set around cut a inch off the end of the log to expose fresh yellow wood it makes the blade last a lot longer pm me if you want to talk about it JB
  10. Ward Hoarder
    Ward Hoarder
    West Virginia
    UPS just came. To late to put on today, have to get ready for work.
  11. JB Sawman
    JB Sawman
    pennsylvania
    Yes I understand work gets in the way of more work?? I have the same issues:headbang:
  12. Ward Hoarder
    Ward Hoarder
    West Virginia
    All back together and no parts left over. Trying some rodent repellant, hope it works.
  13. JB Sawman
    JB Sawman
    pennsylvania
    Its always a good thing when there are no parts left over Hope that stuff works to keep the varmints out JB
    farmer steve and T.Jeff Veal like this.
  14. fezdawg12
    fezdawg12
    Elko, Nevada
    Red about a little trick with enclosed spaces that I have found to work great. Irish Spring bar soap.
    Believe it....or not!
    farmer steve and JB Sawman like this.
  15. JB Sawman
    JB Sawman
    pennsylvania
    It worked for a little while then my mice ate the soap????? they must have wanted clean teeth:rofl: :lol:
    farmer steve likes this.
  16. fezdawg12
    fezdawg12
    Elko, Nevada
    Wow. Very surprising!!
