Cold Wind in the Winter, Does it Season Wood Stacks???
Discussion in 'The Wood Pile' started by Nordic Splitter, Jan 28, 2020.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    Crazy question I know....All the time I feel a warm breeze in the summer on my wood stacks..I know its slowly seasoning my stacks...Got me to think...What about a cold, dry breeze...Does it have any effects???Is it just too cold to matter?? :)
  2. papadave
  3. jrider
    jrider
    Wood dries in the winter but not nearly as much as summer, especially if your stacks get any sun
  4. Horkn
    It definitely does dry in winter, but it dries better in summer.
    Chaz, Screwloose, brenndatomu and 8 others like this.
  5. billb3
  6. Jim Barry
    Jim Barry
    Loch Katrine, Nova Scotia
    Humidity plays a role. Dry winter air will easily speed up the drying process with a breeze and good air circulation.
  7. jrider
    jrider
    I would disagree with this statement. Yes, humidity values are often fairly low in the winter but evaporation rates are much higher in the summer due to the fact that warmer air holds more water vapor. Currently it’s 39 degrees with 51% humidity and the air feels dry. If it were 91 degrees with 51% humidity you would say it’s humid out.
    Another way to look at it is to pay attention to wet roads, sidewalks, yards, and other surfaces. In the summer, they all usually dry pretty quickly. In the winter, they all stay wet for hours, often lasting into early afternoon.
  8. Backwoods Savage
    Ask the folks who live in Alaska and other areas like that.
  9. Skier76
    Skier76
    CT and SoVT
    I've thought about this before too. In theory, I'd imagine it dries a decent amount. Given how dry my hands get in the winter, it has to count for something!
    Seriously though, it tends to be dry in the winter and I'm guessing that pulls moisture out; even if it's frozen. After all, ice cubes will eventually wither away in a frost free freezer.
  10. jrider
    jrider
    But how much of your dry skin is due to being indoors where humidity levels can be extremely low?
  11. Skier76
    Skier76
    CT and SoVT
    That could certainly factor in! I do run a lot of humidifiers; both at work and home.
    Maybe I should put firewood in the freezer and see if it dries out...
  12. billb3
    How will you replicate the evaporative capacity of your local winds ?
  13. Felter
    Felter Banned
    chicago
    ever notice how ice cubes slowly disappear in the freezer? its cause when its below freezing. there is usually zero humidity. also why when working outside without sweating, in sub zero weather you get thirsty more often that working in 35 degree weather, without sweating.
    as many others have stated. wood does season in winter especially below 0*F but not nearly as fast as it seasons in summer.
  14. jrider
    jrider
    Youre right and to only illustrate both of our points, take those ice cubes in the freezer and see how long it takes them to disappear. Now do the same test but put the ice cube tray outside in the summer- and it can even be in the shade. Which tray is empty first?
    Chaz, Screwloose, Woodwhore and 6 others like this.
  15. iowahiker
    iowahiker
    NE Iowa
    I read during the past year that six winter wood drying days is equivalent to one summer day and decades of c/s/s and drying experience gives me no reason to doubt this ratio, six winter days to one summer day. Official winter is 90 days long, Dec. 1 to March 1, and so a winter produces 15 summer equivalent days of drying, i.e. not a lot.
    Sublimation of water in winter is tricky because it requires air-ice contact. My wood will crack internally as it dries and have water migrate into the crack if the wood is "wet". During the winter this internal water is obviously ice but sublimation can not occur if air does not circulate into the ice filled crack. In the summer, the internal water will "wick" along wood fibers and so dry.
    I try to c/s/s as much wood in the fall as storage room permits but those 15 "summer equivalent" days over the winter are just a little "helper" on the path to dry wood.
    Chaz, Screwloose, Woodwhore and 7 others like this.
  16. Slocum
    Slocum
    North Central Indiana
    I will be happy if my wood just holds its own this winter. Meaning it don’t gain moisture, it’s been mild so far. If you split in the winter sure the surface dries and the ends might crack a bit but I make sure my wood is css by spring and it’s ready for the summer heat. The sooner you css your wood the better off you are no matter what time of the year but I count on summer to do the most drying.
  17. buZZsaw BRAD
    Yes. Not as much as the Summer of course. I work outside. My hands and fingertips crack like hell, unless i take care of them. Lots of times i have to work gloveless to use my hands. Has to dry the wood as well.
  18. Jim Barry
    Jim Barry
    If all else fails, just do this :)
    JOTULMAN, Chaz, Marvin and 12 others like this.
  19. billb3
    I see a massive potential for a big mess.
  20. Jim Barry
    Jim Barry
    What am I in for?
