22 Ton, 25 Ton or 37 Ton....is there really a difference??
Discussion in 'The Wood Pile' started by Nordic Splitter, Jan 19, 2020.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    Decided to finally bite the bullet and purchase a wood splitter this spring...With that said...Concerning Tonnage...Is there really a difference>>> I mean is there anyone out there who has found some wood that a 22 Ton just won't split??? What about a 25 Ton or even a 37 Ton? Most of the wood I get is Ash, Maple, Cheery, some Elm and Locust....along with a log load of Pine every now and then. I'm thinking a 22 Ton will be fine...but want to make sure...
    TBONE, FatBoy85, metalcuttr and 5 others like this.
  2. yamadog
    yamadog
    pa
    got a 35 ton organ have yet to find a pice of wood to stop it i split oak,ash,gum,beetch,birtch,hickory,walnut, way i understand lower ton faster they are.
  3. Felter
    Felter Banned
    chicago
    I had a 25 ton. I never found anything it couldnt split thru. crotches, gum sycamore. cottonwood. it ate em all.
  4. Chris F
    Chris F
    Micksburg, Ontario
    I never had a problem with my 22 ton either. I just wanted the security of a full beam and you know, bigger is better and all that.
    Woodsnwoods, TBONE, FatBoy85 and 7 others like this.
  5. Slocum
    Slocum
    North Central Indiana
    I’m wanting a bigger splitter for 2 reasons, log lift and a 4 way wedge. If your ok with a smaller splitter I’d be looking at cycle times. I bought my 22ton Duerr 27 years ago used. 2 engines, a cylinder and a valve later it still does what I need it to do. It’s just slow.
  6. brenndatomu
    You are right...it will split 99% of what you throw at it...chances are that if it wont split it, a larger splitter may, but it would probably just more or less smash it into shreds...kinda like splitting some nasty elm.
    Heck, I have a 5 ton electric that will split most stuff...
  7. Locust Post
    22 ton Huskee, have never stopped it, had a few pieces of Elm it sliced rather than split. If I run into something that it won't split it can go on the firepit.
  8. Ejp1234
    Ejp1234
    MD
    I have a 27t, but 99% of the wood i cycle rarely slows it down at all.
    what would be more important to me than tonnage, would be that it hinges between horizontal and vertical.
  9. brenndatomu
    And cycle time...most large tonnage consumer grade splitters are slow
  10. yooperdave
    I bought a 37 ton for the wood I was getting. Yes, I used all 37 of them. Had to take off the 4 way and it still bogged down into low for the stuff I had.
    For the most part of what I see on here, 22 would be more than adequate.
  11. Gpsfool
    Gpsfool
    U.S.A.
    Difference - cost. :)
  12. creek chub
    creek chub
    Va
    Ditto to the above post about a 22 ton duerr. Been using a really old one for about 10 years. Splits everything I’ve ever loaded up. It’s slow but plenty strong enough.
    I did just buy a Countyline 25 ton that’s way faster and has a log catcher. For me, cycle time and the weight of splitter was the main factors.
    I keep the duerr in the pasture and the Countyline in mountain portion of the property. I’d still be using the duerr exclusively but there are times where I would rather not transport the splitter around much and having two works better
  13. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I have had a 22 ton Speeco for years, I have yet to encounter any thing it wouldn't split. The 16" elm was a struggle, but the 42" oak was a breeze (for the splitter not me)
  14. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I have a 25 ton county line. I run the engine at about half throttle, and have yet to encounter a round I couldn't get through.
  15. Yawner
    Yawner
    Louisiana
    I have one, too. Curious, why do you run at half throttle? I guess you think there is no harm to the motor? I don't know... it seems I recall something like a zero turn mower, they recommend full throttle, don't putt putt around like my elderly neighbor lady. I always wonder is she hurting her mower. I do know for sure, half throttle is quieter! But on a splitter, cycle time is longer.
  16. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I run it that way because as you said, it's much quieter, and will use less fuel. Cycle time difference is negligible to me.
  17. Mwalsh9152
    Mwalsh9152
    Pelham NH
    This one is probably the quietest, but it's only 1hp
  18. farmer steve
    farmer steve
    top of the hill york co. PA.
    25T county line. No problems with anything so far. Biggest thing is reading the wood. Ask bear 1998 how anal I am.:loco: :crazy:
  19. brenndatomu
    I run mine about 1/2 to 2/3 throttle too...it wont hurt a thing....same with the mower, as long as you have enough power/speed to do what you want to do, set the throttle where you want it...the only thing with mowers is some models want you to start the blades under specific throttle settings so that the belt doesn't jump off upon engagement...once running you can adjust the throttle as desired...higher engine speed means a better cut, especially if you want to travel fast.
  20. Backwoods Savage
    Ours is a 20 ton with a 5 hp engine. Does just fine and has split well over 300 cord of wood.
    Perhaps the nicest thing about the smaller splitters is that they are quieter, use less gas and oil, start easier and are less costly to purchase.
