Drying wood around the stove
Discussion in 'The Wood Pile' started by bushpilot, Jan 17, 2020.
  1. bushpilot
    bushpilot
    Eastern Washington
    A friend of mine, a new wood burner, apparently thought that drying wood around the stove was a good plan. I had never seen him do it, otherwise I would have pointed out the danger to him.
    So last week he goes to work with the stove burning, and a split about 3 inches away from the stove (30-NC). Ten hours later, he comes home to a house full of smoke.
    No flames, no loss or damage other than a heavy smoke smell throughout the house, and charred firewood. Could have been worse.
  2. MAF143
    MAF143
    North Central OH
    Can't like that... Glad all are OK, but smoke is still a mess to clean up...
  3. Eric VW
    Glad it wasn’t worse for your friend.
  4. brenndatomu
    I work with our local fire captain...he said the amount of times they find wood right next to a stove would surprise you...:picard:
  5. sirbuildalot
    sirbuildalot
    Mass
    We got called to fire because a guy tried to dry firewood in a kitchen oven
  6. blacktail
    blacktail
    PNW
  7. yooperdave
    You guys are serious about that 3 year plan?????
  8. T.Jeff Veal
    Glad it wasn't worse.
  9. Canadian border VT
    Wow I thought a firewood Split had to be around 500° just to combust without flame.. Hard to keep my stove top temp that high for 10 hours
  10. brenndatomu
    At first, yes.
    The exact temp varies (with wood species among other things) but I think it is something like 450*F ish...but time and heat (pyrolysis) makes it drop...I've read reports of wood igniting from a heat source that was under 200*F with no open flame...granted, it was in an old building and the wood had experienced decades of pyrolysis.
  11. TurboDiesel
    just wow....
    The Good Lord is watching out for him.
  12. Canadian border VT
  13. Backwoods Savage
    Sad, but we see pictures of guys doing it then posting on the Internet. So some dummy who can't think for himself see it and sure enough, has to try it...
    yooperdave, Ron T, Chaz and 11 others like this.
  14. Screwloose
    Last year my son was drying his leather gloves on the stove and forgot about it. That smell was difficult to get rid of.
  15. Horkn
    3" is pretty close. Not smart, but the guy is lucky.
  16. iowahiker
    iowahiker
    NE Iowa
    My understanding is the smoke or ignition temperature of wood decreases with drying and extreme drying can get ignition/smoke point below 300 deg F. Installation specifications for pipes and ducts consider the lower ignition temperature caused by extreme drying. Extreme drying actually changes the wood properties to approach paper characteristics.
  17. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I've been guilty of doing that myself my first year wood burning. However, only when I was home, and around the stove.
  18. brenndatomu
    Definition & Explanation of Pyrolysis
    Chaz, papadave, Horkn and 7 others like this.
  19. jo191145
    I’ve done it. A little common sense goes a long way. Infrared thermometer helps too. Closest splits usually hit about 150 with the stove at highest temps. Some nice dry heat goes a long way.
  20. Pricey106
    Pricey106
    Northeast PA
    I am guilty of this...so far 3 seasons with no problems. I am thinking it depends on the stove type. My quadrafire has a outer plate on the side with a 2 inch air gap. At normal burning temps that outer plate only gets to 175 to 200 the highest. I have measured the temp of the wood many times with the stove running at it's hottest, and highest I got was 125. Maybe that guy had an old stove with direct metal contact. Even the plastic tote in the pic doesn't get any hotter than if it were in direct sunlight, and in the front is where most of the stoves heat radiates to. I am not saying it is the safest thing to do, but neither is running a gas or electric cooktop all day, or even a Crock-Pot plugged in all day. I am thinking about getting a piece of cement board to create a barrier between stove and wood if it makes the safety police happy. 20191025_071446.jpg
    Thor, JB Sawman, Cash Larue and 10 others like this.
