What did you find inside?
Discussion in 'The Wood Pile' started by timusp40, Jan 2, 2020.
  1. timusp40
    timusp40
    Lake Orion, Michigan
    Most likely there is already a thread about this, but let's have some fun again. Not sure what this was but it did this to a piece of oak. What things have you found and did you wreck a chain or what happened? DSCF3844.JPG DSCF3845.JPG
    creek chub, Skier76, M2theB and 12 others like this.
  2. Firewood Bandit
    Firewood Bandit
    I've posted this before but it is still amazing. 3 fox squirrels made the ride home in my trailer after the tree was cut. Bucked on the landing then thrown into the cull pile. DSCF0004.JPG DSCF0003.JPG DSCF0002.JPG DSCF0001.JPG
    Felter, Skier76, M2theB and 29 others like this.
  3. timusp40
    timusp40
  4. Paul bunion
    Paul bunion
    More like didn’t find with this one. Found it when shoveling out the ashes. It must not have been in a piece of oak. The tree guy who gave me the wood missed when he cut the tree and it didn’t show up when I split it either.
    Skier76, M2theB, Screwloose and 14 others like this.
  5. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    Missed this one with the saw, but successfully found others with it.
    Skier76, M2theB, Screwloose and 10 others like this.
  6. buZZsaw BRAD
    Hit this sign bracket cutting a log deck last April. Couldnt see the other side of the log i was bucking. Surprisingly the chain didnt get damaged too bad. Dulled of course, but not really bad IMG_0217.JPG IMG_0216.JPG
  7. buZZsaw BRAD
  8. buZZsaw BRAD
    November 2018 i was bucking this large pin oak felled by tornado earlier that year. It had a spot light on it. Wire was broken off so i knew it wasnt live! All the rounds below the light had the wire and the saw sliced right though the copper IMG_0277.JPG IMG_0276.JPG IMG_0275.JPG IMG_0278.JPG IMG_0279.JPG
  9. buZZsaw BRAD
    more bolts and holes from nails. I think there was a tree fort on this tree. IMG_0281.JPG
  10. buZZsaw BRAD
    Skidder wire in a log deck. Again couldnt see the other side of the log and the chain nicked it. IMG_0464.JPG Turned out it wasnt attached. Found out the next week as i cut farther into the pile of logs. IMG_0511.JPG
  11. GrJfer
    GrJfer
    The Woods of Arkansas
  12. buZZsaw BRAD
    Same log with sign bracket only being split. Had to leave it in double length round to split IMG_0584.JPG
  13. Eckie
    Eckie
    GrJfer's hitting gemstones! Opals or something!
  14. buZZsaw BRAD
    chunk of metal buried in leaves. Nicked the edge as it blended in. IMG_1047.JPG IMG_1048.JPG
    Same tree from prior nail hit. Turns out there was a tree fort in the oak. IMG_1443.JPG Same tree nail in split IMG_1454.JPG
  15. MAF143
    MAF143
    North Central OH
    Pretty sure one of the contractors was checking his nail gun when our house was built in '07. Chain survived after a serious filing. It was in the first notch cut I made in the tree by the driveway. I told my nephew that was helping me that day that I had just sharpened the chain the night before and I couldn't figure out why it was cutting so bad. I was about to take my files away from myself for being crappy at sharpening!!! I saw the chain was dull and put about 15 strokes per tooth on it and finished cutting the tree down. Then we found this... 16 penny framing nail...
  16. FatBoy85
    FatBoy85
    Washington State
    Looks like either a phone line ground or a laundry line hold!
  17. Firewood Bandit
    Firewood Bandit
    Well they were mighty terrified. I tried to shoo them away and they were having none of that. They stayed in the hidey hole. I went in and took a shower and 40 min. later were still there. Went golfing and were gone when I came home.
  18. buZZsaw BRAD
    thats $@#%$. Worst way to hit a nail.
  19. Phil121
    Phil121
    7F980A8D-3BA2-4109-9E53-E2FFD9A1DB40.jpeg Found a well hid squirrel’s walnut the other day in an old maple crotch
  20. Casper
    Casper
    I was being supplied by a tree service for some time. The bad part is that the trees generally had been tried to be saved years prior to removal. That meant me finding tons of metal in the form of cables, eyebolts, chains and lag bolts.
    Some I found prior to cutting, some while cutting or splitting and some in the ashes after burning. I'm not terribly sad he bought a larger lot in his city and started processing and selling firewood. I had to take larger pieces and they were a pain to manage. I burnt 6-7 cords worth of huge crotches and rotten stuff a few years ago. It doesn't take long to build up.
