red oak and furnace progress
Discussion in 'The Wood Pile' started by Sluggo, Jan 1, 2020.
  1. Sluggo
    Sluggo
    Martin, GA
    Good morning and Happy New year to all! I 'm nearly done with the three fallen red oaks I found here. Looks like I'll get about 2 cords from the three trees. I decided to split into smaller pieces in hopes that it will be ready for next year. Moisture was averaging about 25%. Also tried out the furnace. Outside temp was high 30's. Inside thermostat was set at 70. Furnace raised temp to 74 after 1-1/2 hours so it works but I'm losing a lot of heat as the warm air circulates back through basement heat pump unit and through the ductwork. Temp at outside of duct near the furnace was 110 and at the upstairs registers was in the mid 80's. I might reroute the two wood furnace ducts to blow directly into the registers upstairs to reduce warm air travel path. I also found out that the factory damper on the furnace door is about useless. It's either wide open or closed. I have an idea for a simple adjustable intake damper with a cold air intake from outside. Sorry for all my numbers. I'm an engineer and like to quantify things when possible. All comments appreciated as always.
    imwiley1, Loon, Midwinter and 15 others like this.
  2. buZZsaw BRAD
    Youve made good progress! Nicely done! :thumbs:
    Loon, Midwinter, FatBoy85 and 4 others like this.
  3. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Nice work and post. How do you like the gator? I just loaded mine up with some downed trees myself. Happy New Year!
    Backwoods Savage and Midwinter like this.
