Cleaning plastic
Discussion in 'Chainsaws and Power Equipment' started by Ron T, Dec 30, 2019.
  1. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Just picked up a 034 super. Runs great, but might want to clean the deep grime from the plastic. Any products recommend for the job?
  2. Ron T
    Ron T
    85707561-D3DC-4483-91A1-D69C0B34C2E6.jpeg Thing has a ton of compression. Going to give the muffler the treatment and see how it runs.
  3. farmer steve
    farmer steve
    top of the hill york co. PA.
    I've used this with good results Ron. Cheap at the dollar store. I usually scrape any crud off with a plastic putty knife and a toothbrush for the slots in the recoil. I spray this on and let it soak a minute or 2 and then wash off with water. Nice saw BTW.
  4. Ron T
    Ron T
    Thanks! I’ll look for it.
  5. TurboDiesel
    In the past i would shine up atv plastic with WD 40
  6. Ron T
    Ron T
    Tried it yesterday...didn’t work so well. Really just thinking about running as is!! Aesthetics aren’t really as important as how it runs.
  7. farmer steve
    farmer steve
    One area I have found working on other people saws or used ones I have bought that is overlooked is behind the chain brake mechanism cover. Gets really gunked up in there.
  8. Ron T
    Ron T
    For sure. Going to tear this one down and give it a thorough cleaning. I’m happy with it for the price.
  9. farmer steve
    farmer steve
    Ron 1 other thing I have used to cut really nasty grime is starting fluid. Followed up by air. I only do it outside on really nasty saws. Doesn't hurt the plastics or metal.
    Chazsbetterhalf and Screwloose like this.
  10. Ron T
    Ron T
    May have to pick some up when I run to town for provisions later :coldone::coldone:
  11. unbidden
    unbidden
    RI
    Brake cleaner, but keep it off the decals.
  12. billb3
    Any kind of degreaser/detergent that won't degloss the plastic surface should work. Otherwise you're going to spend some time polishing out that damage which is pretty much the same that happens with the surface aging . Polishing can be time consuming ( I'm not talking a thin coating of wax-like-furniture polish) especially if you are trying to remove scratches and gouges and heavily oxidized surface patina.
    A little steam cleaner like you might have for sanitizing or removing wallpaper with the little small nozzle/brush attachment often works well too. Can use for bug and tar blobs on your car too instead of solvents.
    Chazsbetterhalf and farmer steve like this.
  13. unclefess
    unclefess Guest
  14. eatonpcat
    I use this at full strength to clean just about everything I own... Don't do much saw cleaning, but the one or two times a year that i do, it works great.
