Chainsaw Cleaning
Discussion in 'Chainsaws and Power Equipment' started by iowahiker, Dec 18, 2019.
  1. iowahiker
    iowahiker
    NE Iowa
    We "hoarded" used toothbrushes for years and finally found a good re-purpose for them, cleaning my chainsaw. I usually use the air compressor but that would not work in the field so I tried a used toothbrush. Wow, I easily removed 95% of the dust and deposits that the air compressor removed without stuff flying everywhere. I only needed a quick touch up with the air compressor in the smallest nooks. I used the handle end to scrap out the big deposits and the the brush for the rest including most of the nooks.
    The used toothbrush worked so well I will use the toothbrush first and then a little air. I did use a small putty knife to clean the bar.
    Hammy, Chazsbetterhalf, Chaz and 20 others like this.
  2. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    You can file or grind the handle to use as a scraper. If you have a couple you shape one handle tip small enough to fit the grove in the bar.
    Hammy, Chazsbetterhalf, Chaz and 11 others like this.
  3. Backwoods Savage
    And here I thought every hoarder kept a tooth brush in his tool kit! They do come in handy.
    Hammy, Chazsbetterhalf, Chaz and 7 others like this.
  4. Ralphie Boy
    Ralphie Boy
    Last count I had 6 for different tasks in the hoarding maintenance department.
    Hammy, Chazsbetterhalf, Chaz and 9 others like this.
  5. iowahiker
    iowahiker
    NE Iowa
    In hindsight, it seems obvious to use a toothbrush with a "hoard" but the habit was to use the compressor. The toothbrush was a surprisingly good cleaning tool.
    Hammy, Chazsbetterhalf, Chaz and 8 others like this.
  6. Backwoods Savage
    And now keep one for cleaning the sawdust from around the caps before opening to fill with oil. Great tool for that.
    Hammy, Chazsbetterhalf, Chaz and 6 others like this.
  7. Holland Dell
    Holland Dell
    SW Wisconsin
    I tried this method last night. This morning, my scowling wife informed me I have to use my own toothbrush for cleaning the saw. I assume this means the cat pan too. Just guessing.
  8. Screwloose
    IMG_20191124_134424044.jpg I just got lazy and mounted a compressor on my counterweight. Nice to have air out in the woods.
  9. M2theB
    M2theB
    Central Massachusetts
    Air and tooth brush for sure.
    For picky work and saw salvage projects I found that the burger/sandwich picks at Legal Seafoods are a pretty good tool. I always ask for a few when I get to go there.
  10. Czed
    Czed
    Wv
    dollar tree foaming shower cleaner soak
    and then
    a pressure washer does the trick for me
  11. blacktail
    blacktail
    PNW
    Toofbrushes are great for cleaning stuff. I've found zip ties to be just the right size for picking gunk out of my saw too.
  12. Screwloose
    A few assorted sizes of hemostats works great with small pieces of cloth. Awesome to wipe out fuel tanks.
  13. Screwloose
    IMG_20191222_161445198.jpg I took this pic yesterday of my nephew blowing out the door prize saw that Gary_602z donated at Backwoods Savages GTG extravaganza. Many Thanks Again Gary !! It's become the go-to saw for my son and nephew.
