Bar Oil, How often do you change yours?
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Dec 15, 2019.
  1. M2theB
    M2theB
    Central Massachusetts
    This is the 372xp I grabbed last weekend. Took a few minutes today to run it and checking how well it oiled I noticed it came with a brand I’ve never tried.
    Me guess is Quaker State 10w30 with 8500 miles on it.
    I’d be concerned about the pick up tube if it had one.
    1B069EAD-4147-4474-8B88-CA5212E9F03C.jpeg 7869C179-6145-417C-95B3-22814D80BF39.jpeg
  2. MikeInMa
    I've never thought to drain the bar oil. Just refill as necessary. But never with motor oil, used or not.
  3. cnice_37
    cnice_37
    Ha..... I think synthetic will get you 10,000 cords
  4. T.Jeff Veal
    That is a mess, wash out the tank for sure.
  5. In the Pines
    In the Pines
    looks like a lot of short trips with that milkshake around the oil cap.
    Better run it hard and knock that sludge out of there. :rofl: :lol:
  6. Diesel 4 life
    Diesel 4 life
    Kansas
    Lots of people do this. I don’t know why when bar oil is so cheap.
  7. The Wood Wolverine
    I've heard of people doing this, and also have read why not to.
    Also some run veg oil, which I hear if left to sit can go putrid.
  8. The Wood Wolverine
    P.S. If you don't feel like messing with it, I'll PM you my address... :D
  9. M2theB
    M2theB
    Wish I had seen this sooner!
    Next one!
  10. blacktail
    blacktail
    PNW
    Spend hundreds of dollars on a saw, and then abuse it to save a quarter? No thanks.
  11. Canadian border VT
    Some people make me wonder, glad you rescued that poor tool:yes:
  12. JotulYokel
    JotulYokel
    Missouri
  13. In the Pines
    In the Pines
    thing is they are spending more money by using motor oil. a quart can cost almost as much as a gallon of bar oil.
  14. The Wood Wolverine
    They use it after draining from car/truck use, so it's spent and contains contaminants.
  15. In the Pines
    In the Pines
    chit I guess I was giving them credit and benefit of the doubt for using new oil than.
  16. Scotty Overkill
    Used motor oil is bad stuff for chainsaw bar lube. It doesn't have the tackiness that bar oil does, and it slings into small droplets (mist) that you end up breathing in. .....
  17. ironpony
    ironpony
    Mid Ohio
    The oil out of my Cummins looks better than that at 15,000 miles and it works great as bar lube after it goes thru the engine..................
    Sorry but that is all I have ever used.
  18. Horkn
    Ugh. I accidentally added about a tablespoon of used oil from my trucks oil change to my bar oil reservoir a couple weeks ago. I stopped at soon as I realized that while it was a bar and chain oil jug, that it was what I put used oil into.
    I doubt it will hurt anything, but it has to fling a lot more.
  19. jwebb
    jwebb
    Nashville, AR
    It will sure make a mess running engine oil. I’ve run new oil before in a pinch but other than that it’s always b/c oil
  20. tamarack
    tamarack
    paulina oregon
    I watched a friend do this to a brand new saw about a month ago. I would never even think of running used engine oil for bar oil. If for no other reason than it makes the saw and whatever clothes your wearing stink.
